I've upgraded my 2001 ET2 over the past 4 years, but barely ridden it (50-100 miles). The last I rode it was nearly 2 years ago. Finally living in a city again! Whoo!
I can get it started after laying on the ignition for ~30 seconds or so. I have to pump the fuel, and keep it cranked fully open to get it going, but it hits idle and stays there no problem. It also runs/drives really well- no issues.
It will restart immediately with no issues if very recently turned off, but after 10 - 30 minutes I'm back to the same issue.
Fuel is new.
Oil is full.
Spark plug is new.
Battery is new and fully charged.
Carb was recently cleaned.
Smart Scooterists...Any ideas what might be happening here?
The sound it makes when it doesn't want to start, sounds as though it doesn't have enough fuel at the cylinder. There are no visible cracks or punctures on the "suction line" from the fuel tap.
Lots of new/upgraded parts in the past 4 years including:
- Fuel tap
- Malossi 70cc Cylinder
- Malossi Multivar Variator
- #80 main jet for carburetor
- oil pump belt
- CDI spark plug cap
LISTEN to an audio recording of initial startup, run, then turned off and immediately restarted. http://tru-tone.com/wp-content/uploads/2022/Vespa-ET2.mp3
Thanks for any insight!
