@olly avatar
Lml star
@olly avatar
Lml star
Hi all just had service and new throttle cable and the guy told me clutch smashed when on stand strip it back and fitted new clutch and cleaned all metal bits of engine not sure if poss that bits can get in re fit cylinder head come loose £600 what do you think bit much ?
@srd0060 avatar
2022 HPE 300 tech/ 91 PX 200e/97 PX 200e
@srd0060 avatar
OMG thats a lot of money, did you ask to see the old clutch?
@olly avatar
Lml star
@olly avatar
Lml star
Picking it up Saturday got pic and parts they took off I was thinking £400🤷🏻‍♂️
Lambretta GP200, Vespa P200e, Motovespa do Brasil PX200E
that made ZERO sense. But sounds like alot of dough for what sounds like something minor.
@robbie_11 avatar
PX
@robbie_11 avatar
PX
I also cant make sense of what your trying to say?
Can you try explaining again?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Let me see if I can translate:
Olly took the scoot in for service and a new throttle cable …
The mechanic said his clutch was bad …
The mechanic replaced the clutch and cleaned metal bits out of the case.
The mechanic also apparently tightened up the cylinder head.
Olly was charged £600 and wonders if that's fair.
@spacecat avatar
Vespa Primavera 1974
@spacecat avatar
That's about 750 USD$
Can you get a breakdown of the costs. parts, number of hours, hourly rate?
Jet Eye Master
Jet Eye Master
Clutch probably 'smashed' during the wheelie check while onthe test ride!
@shipscat avatar
vespa 125 vnb1t
@shipscat avatar
vespa 125 vnb1t
you should try and join a local scooter club there are usually guys that have a ton of knowledge repairing and fixing them , i don't know all the details of your bill but it sounds like had your pants pulled down there fella
or if you have some space at your house/garage/shed and some time and don't mind getting your hands dirty get yourself some tools and learn to fix it yourself there's an encyclopedia of knowledge on this excellent forum with people willing to help and walk you through with pretty much what ever you need
@vintagescooterdude avatar
2006 GT200 2009 Genuine Stella
Not sure what "clutch smashed" means. Just worn out or something broke? What does the stand have to do with it? Is it a 2T or 4T? I have a 2009 Genuine Stella 2T (same as an LML Star) that I bought new. It now has 21,000 miles on it. Still has the original clutch. I have a rebuilt (with some high dollar parts, including a big bore kit) Vespa engine that was built by a local vintage Vespa shop ready to go in it when the original engine ever wears out.
@chandlerman avatar
Lucky
75 Days Since Last Explosion
Lucky
@chandlerman avatar
I agree with the other posters on here that, even assuming worst-case scenario (destroyed clutch), that doesn't make sense.
A new stock 7-spring clutch is 52 GBP on Beedspeed. Pressure plate and plunger are another 5 GBP.
So call it 60 GBP of parts. A clutch swap takes 20-30 minutes, plus maybe another 10 minutes to adjust it. Use the rest of the hour to pull the shroud, tighten the head nuts, and reinstall, then take a quick test ride.
That's still 540 GBP for an hour of labor! Wha? emoticon
Which is a lot of words to say, Yes, you were ripped off.
@mjrally avatar
@mjrally avatar
OP says service, a throttle cable, clutch and head refit/replacement?? So inspection and service- probably an hour there @ labor rate. Then throttle cable replacement another hour, maybe 1.5? Then clutch install, testing and tidy- 1.5 there?
So maybe 4 hours of service plus parts, hazardous waste disposal fees (if any), taxes, random fees, storage charges (maybe) for £600. Seems plausible
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Okay...forgot about the throttle cable replacement, but that's well under an hour, especially with the split headset on an LML. I'm also curious what the original symptom was. Throttle cables basically never wear out. There's just not enough load on them.
At this point, I think I'm with Matchless that we need to see the invoice to understand what did or didn't go on here. That still feels like a lot of labor to me.
What's the typical UK labor rate for vintage scooter work, btw?
I did a little googling, and found a place in Manchester (trying to avoid London price inflation) that list fixed service prices.
While they don't list an hourly service rate, their full 30km rebuild is only 450 GBP, all in.
[ Time: 0.0123s ][ Queries: 3 (0.0018s) ][ live ][ 313 ][ ThingOne ]
