83 P125X
83 P125X
The rear turn indicators on my 1983 p125x stopped working when I pulled it out this spring. They worked before putting it away for the winter. Bulbs are fine. Front indicators work fine. What should I check next?
PX125
PX125
Check the connections between the side panels and loom.
px 125 disc
px 125 disc
I recently had this problem and eventually tracked it down to the rivet on the spade connector on the light unit not making contact with the said connector.
If you work through methodically with a test meter ( cost about a tenner) youll find the problem
@chandlerman avatar
Lucky
69 Days Since Last Explosion
Lucky
@chandlerman avatar
Yep, it's either bad connectivity or maybe you just need to top off the blinker fluid Razz emoticon
If it's both of them at once, I'd start by looking for a bad connection to ground.
[ Time: 0.0089s ][ Queries: 3 (0.0021s) ][ live ][ 313 ][ ThingOne ]
