So I had a soft seize. Again. Second time since October.
Both fresh rebuilds. 2nd oversize on the cylinder the first time. Rebooted to 3rd oversize the second time. Rings were gapped appropriately. (0.4mm I believe).
The first time I thought it was due to poor jetting.
Second time—-first ride out. Not going hard. Just a nice break in ride. Maybe 1/2 throttle. Booom. Soft seize again.
Piston is free. A mark on the cylinder wall but no deep gouges I can catch w my nail. Haven't taken the cylinder off to assess the piston or rings.
Jetting was on point. brand new plug.
So what is it? Could have been the timing bc I never verified it. But it's a p2 and I trusted the timing marks.
I made a homemade leak tester and gave it a shot. I pump it up. No bubbles anywhere. However the cases won't hold air. No bubbles to be found when spraying soapy water. Can't find the leak anywhere. Cant feel the air escaping either. Not at cylinder base or head. Not at carb or exhaust. Not at clutch breather. Not at rear hub. Not along casings where bolts attach.
So what do I do now? Thoughts?
