@dougw avatar
1974 Rally200, 2007 GTS250ie
@dougw avatar
I need to change my oil and replace the O-ring on the oil drain plug. O-ring size is apparently 31.47 x 1.78. There are no Vespa dealers near me to buy this weird size, and paying $10-15 shipping for a $2 O-ring seems rediculous. Can I use a 32.00 x 2.00 O-ring or something similar from the hardware store, or does it have to be that special size?
@greasy125 avatar
@greasy125 avatar
is yours split, cut or otherwise compromised in some way? if not, just go ahead and reuse it. it'll be no big deal.
you can cram a bigger o-ring in there, but it's not ideal. may result in leaking or getting an improper torque on the drain plug and it either being overly tight or too loose and working its way out. use some sticky grease to get it to stay put and hope for the best.
personally I'd recommend biting the bullet and ordering up one (or a few) and just tack a few extra consumables on there to make it worth your while.
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
^ this.
You can safely reuse an oil plug oring if it is undamaged. I have many times. You can't safely assume an oring from a hardware store is a suitable material for hot engine oil. It may be suitable for water only. (EPDM rubber for plumbing service). If you must gamble, a better source would be an auto parts store. Better yet, as recommended above, order some spares from your dealer along with an oil filter and a belt.
@waspmike avatar
@waspmike avatar
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
Would this https://www.harborfreight.com/397-piece-metric-o-ring-assortment-67580.html qualify in terms of application i.e. work in this environment for use with the drain plug
My typical M.O. For a while I think it added 20% to my cost of riding though. Facepalm emoticon
Which reminds me...I have half a dozen oil filter rings from my old BV which I sold..... freecycle thread, here I come!
⚠️ Last edited by fledermaus on UTC; edited 1 time
@tinddu avatar
2022 gts 300 touring
@tinddu avatar
greasy 125 is right! i would buy 3 or 4
I confess I've never, ever replaced one in all the years I've had Piaggio scooters. They've always been in good condition.
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
I just bought 4 the other day, along with a spare oil drain plug. You never know when one will be needed.
@wbdvt avatar
@wbdvt avatar
Usually a place like Ace Hardware has parts drawers that have orings or you could go to an auto parts store with the oring and they may be able to match it.
Vespa 150 LX
Vespa 150 LX
I recommend YouTube... West Coast Scooters has a very good series of general maintenance videos for Vespas...
They have parts, too.
[ Time: 0.0090s ][ Queries: 3 (0.0030s) ][ live ][ 313 ][ ThingOne ]
