After disassembling the front end on my 2001 ET4 Vespa to replace the clock battery it turns out the clock is bad, common problem. But now that I put the front end back together the head light and both turning signals don't work.
I have a working horn and working brake light and oddly the small running light in my headlight is lit yet does not turn off when I toggle the light switch.
I've checked the fuses located behind the storage shield. Both are good.
Where did I go wrong?
I'm thinking to open it up again and revisit both headlight and turn signal selector switches?
Anybody out there care to comment?
Thank you,
Joe in Carefree,AZ.
