@grandpanate avatar
@grandpanate avatar
Question for the hive mind…just offered up my Malossi 210 piston to the crank in the motor I'm building for for my Rally. When I put wrist pin in with the clips there's a gap between the pin and the wire clips. Bad? Don't worry about it? The wrist pin is from an older Malossi piston I had as I can't find the one that came with the kit.
Just want to make sure I'm good to go before I button this thing up.
Cheers!
Nate
@grandpanate avatar
@grandpanate avatar
Pin pushed against clip
@108 avatar
V range 50s
@108 avatar
V range 50s
It's normal.
Newer 2014 kits are the same.
I usually make sure the c clip is installed properly and the gap faces the top or bottom of the piston.
@grandpanate avatar
@grandpanate avatar
108 wrote:
It's normal.
Super a lot big thanks! Puts the mind at ease!
@108 avatar
V range 50s
@108 avatar
V range 50s
If you can get a chance, a good upgrade to the older kits, is to widen the exhaust port.
If I remember correctly, something like 60mm (I need to find my old notes).
And also enlarge the piston windows.
It's copying a German workshop technique. I tried it on a stock 210 setup, and it just ran faster.
@grandpanate avatar
@grandpanate avatar
Nice!!!
[ Time: 0.0107s ][ Queries: 4 (0.0028s) ][ live ][ 313 ][ ThingOne ]
