@kb6emh avatar
2016 sprint 150 / 2005 PX 150 / 2012 HD FXE
@kb6emh avatar
Can someone tell me approximately what the parasitic drain is in mA for a 2015 Vespa sprint? No options/alarm. Just clock and immobilizer.
Battery charges but goes down in about a week. New battery. Charge holds at 13.1v. Charge voltage is approx. 13.9v - 14.2. Alternator seems ok….not sure about voltage regulator.
Any help would be appreciated
Sorry for posting in Not so Modern
Couldn't get GD to load at first. Darn Apple product!
2009 mp3
2009 mp3
Borrow a meter and measure it. Pull one of the battery leads off and connect an ammeter between it and the battery.
if doing what oldgoat says shows more drain then you feel is acceptable then while doing that try removing the different fuses to see which drops it a lot. compare this to the wiring diagram for understanding
@crackedegg avatar
2018 Vespa GTS300
@crackedegg avatar
2018 Vespa GTS300
Battery goes down to what? 12.6 volt is fine.
[ Time: 0.0084s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
