Gts250ie
Gts250ie
Hi All, This might be a rookie mistake. I have just changed the drive belt and reinstalled the clutch bell and cover. After I torqued the nut down the rear wheel locks up.
However when loose the rear wheel spins freely.
I double checked the clutch nut to make sure it is not scrapping the bell.
The play on the spring on the clutch and the tension seems good
Maybe it is something on the drive end variator. I noticed that the belt is really tight on that end. Could be I am missing a washer?
2012 GTV300, 2007 GTS250
Are you putting the nut on before the belt cover? And there is a washer under the nut.
@grahamlml avatar
Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
@grahamlml avatar
Belt trapped between the Variator pulley halves when tightened down. See if you can turn Variator reasonably freely without out belt turning if held.
@jkj-fz6 avatar
@jkj-fz6 avatar
Shouldn't the rear wheel and clutch bell turn freely even if the belt is caught? Seems to me the problem is in the clutch.
@grahamlml avatar
@grahamlml avatar
Now I had time to think properly you are right.
Gts250ie
Gts250ie
Clutch Washer and nut are after I put on the cover on the outside of the bearing in the cover
@madison_sully avatar
I'd suggest you take it apart again.
And this time, when assembling, do two things.
First, get the belt much deeper into the clutch before you put the clutch back on. The belt should be quite loose in the variator when you tighten that nut down.
Second, when you do put the clutch with belt back on, make sure there is nothing blocking it from being fully inserted onto the shaft.
That's a thin washer, right? Not a 1/4" thick one? Some earlier models had such a washer and it had to go on the inside, between the bell and the cover. Later models had the equivalent thickness added to the bell.
Gts250ie
Gts250ie
Correct..there was no washer between the beel cover and the clutch. Only a thin washer and nut on the outer side of the bearing on the belt cover
GT 2.4
GT 2.4
Make sure the cover is completely on the bike, use a couple of the middle bolts to hold it in place, then put on the clutch nut and washer.
Gts250ie
Gts250ie
I just realized I am missing item #9 on the assembly drawing. Wonder if that would do it
GT 2.4
GT 2.4
No, but not having it will destroy your variator in short order.
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Sometimes that washer becomes stuck to the outer variator half.
@crackedegg avatar
2018 Vespa GTS300
@crackedegg avatar
2018 Vespa GTS300
Maybe a video of a disassembly and reassembly of the transmission will help you find your error. Starts at the 12 minute mark.
Gts250ie
Gts250ie
[quote="CrackedEgg"]
Thanks for the post
@crackedegg avatar
2018 Vespa GTS300
@crackedegg avatar
2018 Vespa GTS300
Thanks for the post
Hope it helps. The rear tire looks brand new. Did you take the wheel off just before doing the transmission? Was it reinstalled correctly?
@donttellmywife avatar
09 250 Super
09 250 Super
I agree with those above. confirm that the front variator plate has'nt pinched the belt stuck. Then reset the belt inside the clutch to be as deep as possible. just squeeze the clutch with both hands, it will fall into the groove further. is it possible to post a short video of what its doing ?
Gts250ie
Gts250ie
My bet is the variator is pinching the belt sin e I have not placed the belt deeper in the clutch. Once I get the thin washer in between the two variator disc I will post a video before clutch nut install and after.
Gts250ie
Gts250ie
So I received the washer that goes between the variator halves and installed it. That was NOT the issue. It turns out the washer I used for the clutch nut was larger than the OEM recommended and was clamping on the bearing when torqued. Used the right washer and am back to riding. Thanks to everyone who gave me some great tips and helped me troubleshoot this.
@berto avatar
@berto avatar
Thanks for posting the resolution to this problem.
Assuming it all ran before this work, I'm really confused how you came to have a "too thick" washer there. I might have missed it, but I don't think you said you replaced the clutch itself? So where did this bad washer come from?
2001 ET4, 2007 GTS250, 2011 GTS250, 2021 GTS300 Supertech
Glad you sorted it and I'm impressed you made the effort to do it yourself.
Threads like this make me glad I pay my mechanic $500 to do the job. It would drive me bonkers otherwise, although I like to troubleshoot A/V issues so each to their own 🙃
[ Time: 0.0137s ][ Queries: 4 (0.0074s) ][ live ][ 313 ][ ThingOne ]
