@xperimental21 avatar
Super
Super
Let say if I have stock P150X engine and aim for better gas mileage but good performance for daily ride and fitted Polini Box exhaust, which carb setup gives better mileage?
SI 24/24, up jetted, and tight pad clearance
or
PWK/PE 24 with reed valve.
Also, is it possible to make a custom expansion chamber which optimized for low-mid rpm as what the stock engine normally run?
px 125 disc
px 125 disc
or
Unless you're set on an expansion chamber a polini box will give you all the bottom end grunt you need, I've got one on my vmc super g and it pulls ( a sidecar) from very low down all the way up to 7500rpm. comparable if not better than a px200.
@chandlerman avatar
Lucky
68 Days Since Last Explosion
Lucky
@chandlerman avatar
Your best option for better gas mileage is keeping the motor bone stock.
After that, your next best option would be a si 20/20. You're not going to be able to pump enough air to get the 24/24 working well, so it'll be tough to tune, especially in the 1/4-1/2 throttle range.
px 125 disc
px 125 disc
Agreed, and the smaller carb will give you a better bottom end, and in theory if you've got enough grunt you could up gear to improve your fuel consumption.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Forgot to answer this...short answer: No.
Longer answer: one of the Big Box exhausts will get you some resonance on the top end while still being quieter than a full expansion chamber. It'll give you a wider, flatter, but also somewhat lower max HP power curve.
For most people, that's what they want for day-to-day riding. Less shifting, but not much more noise than stock.
Super
Super
Would that resonance from big box also pulls the mixture back into the combustion chamber?
1979 smallframe, bajaj Priya aka VBB, PX150E Disc Brake
Yes. That funky segmented expanding pipe leading to the box is there for that.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Yep. If you cut one open, you'll see that a cone intrudes into the box, but doesn't narrow back down like a proper tuned pipe, so basically a semi-tuned pipe.
[ Time: 0.0116s ][ Queries: 3 (0.0027s) ][ live ][ 313 ][ ThingOne ]
