Vespa ET4
Vespa ET4
Hi all,
I changed the transmission belt and the variator (it was overused) and when I tightened the rear nut (of course, at the torque set by the manufacturer of 54-60 Nm), the rear wheel almost locks (it turns very hard) does anyone know why ? Thank you!
Did you squeeze the rear pulley so you could put the belt deep down in it?
Vespa ET4
Vespa ET4
Yes!
@slowpoke avatar
1952 allstate (early), 1958 allstate, 2009 S150, 2001 ET2
@slowpoke avatar
Have you spun the belt with the rear pully around a few times to make sure the belt has settled in place?
Vespa ET4
Vespa ET4
No, I will try this again in weekend.
@slowpoke avatar
@slowpoke avatar
One place it can start to bind up is with the metal washer at the front off the variator. If the belt gets wedged there at could cause the issue.
[ Time: 0.0087s ][ Queries: 3 (0.0026s) ][ live ][ 313 ][ ThingOne ]
