Vespa GT200
Vespa GT200
I have multiple helmets. I don't need a sena and I don't want to keep changing the headphones back and forth.
Any suggestions for reasonable priced headphones to put in helmets?
$120 for these is nuts.
https://www.amazon.ca/KONNECT-Wireless-in-Helmet-Adventure-Headphone/dp/B07LFMCF16
I don't see that you need something labelled a for motorcycles?
I gather many riders are happy with apple airpods. probably other decent similar brands would also be nice like the google pixel buds or samsung galaxy buds or sony etc. Plus most of these offer noise cancellation
@waspmike avatar
@waspmike avatar
BT-12 or BT-22. About $15.
BT-22 is newer but it comes with a microphone attached which I cut off. BT-12 is older tech but comes with a microphone that can be unplugged. BT-22 is stuck onto the helmet, BT-12 is a clamp-on.
Vespa GT200
Vespa GT200
Excellent point, but I've tried (wired) buds before and the helmet just mashed them into my ears to the point it was painful!
@waspmike avatar
@waspmike avatar
How to get those to stay in the ear when putting on a helmet? Suggests that some are wearing oversized helmets.
Then again some cheaper helmets don't have a built in pocket for the in-helmet speakers.
The OP doesn't want to
@johnymoore avatar
@johnymoore avatar
I have ordered these https://www.ucleardigital.com/shop/helmet-audio/powersports/pulse-helmet-speakers/
You can attach a bluetooth receiver but I think I will just go with them wired to my pocket to have one less thing to charge.
Vespa GT200
Vespa GT200
Great option, thank you!
@mayorofnow avatar
2020 GTS 300 HPE
@mayorofnow avatar
2020 GTS 300 HPE
A Cardo is just a set of speakers like this plus a Bluetooth bridge. They sell the speakers separately.
I've had a couple Cardos die in the rain. Being able to hardwire the speakers to my phone with the audio extension cable that you can get at any electronics shop has been a saving grace on two separate tours. Now, I carry the extension cable when I tour, just in case.
@miguel avatar
@miguel avatar
I've done several posts over the years about using Apple's AirPods Pro and Pro II to reduce noise inside motorcycle helmets. This is the latest one: [UPDATE] Reducing helmet noise level with AirPods Pro II. My focus was reducing in-helmet noise (They are excellent). The sound quality is also excellent tho I don't listen to music while I ride. There's a lot of info in the thread above. Perhaps the AirPods Pro II would meet your requirements. They are pricey tho.
Best
Miguel
⚠️ Last edited by Miguel on UTC; edited 1 time
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
With Sean you can buy the mount kits separately. Install mounts in each helmet and move the control unit between them. Bonus, you only need to sync one unit to your phone/GPS.
@mayorofnow avatar
2020 GTS 300 HPE
@mayorofnow avatar
2020 GTS 300 HPE
I think autocorrect ate "Sena." Same is true of Cardo. They're called "second helmet kits."
Sounds like the OP is looking for something cheaper, but that's where my head went too.
@waspmike avatar
@waspmike avatar
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
You are right it did. Frankly, the few "cheap" ones I've tried weren't worth even their low cost.
@rrider avatar
@rrider avatar
Semi-helpfully, I can identify a potential challenge with wireleds buds too:
I have Samsung Galaxy Buds2 pro buds.
In normal use, excellent fit, very comfortable to wear.
Noise cancellation is quite mild - not even close to the best full size noise cancelling headphones (e.g. Sony 1000-XM...etc.)
For helmet use: these buds are quite small, so they have enough room to be inside my helmet without any pressure. But, it is almost impossible to get them to stay in their place when putting the helmet (full-face) on.
So in case of wireless buds, this is a thing to watch out.
Samsung buds look like this, they are small.
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
I know you're not asking for a comms unit, but consider it bonus safety gear. If you go down, depending on the unit you have, you may be able to make an emergency call for help without removing your helmet. If you have a hands-free unit, you may not have to lift a finger to make the call. Food for thought.
The inaugural run with my Cardo Palktalk Edge was multiple hours in the rain. I noticed before I rode out that the charge port cover wasn't closed tightly. The visual difference between looking closed and truly sealed is very slight. Mayorofnow's issues may have had a different cause, but I double-check it before each ride to be safe. YMMV.
I wear foam earplugs to prevent the worsening of lifelong tinnitus, and the Cardo speakers have adequate volume, but I'm considering upgrading to the larger speakers to compensate. Without the earplugs, the sound is fantastic.
This is a basic comms unit that will allow you to listen to music, hear directions, take/make calls, and talk to one other rider.
https://www.cardosystems.com/shop/spirit/
Same as above with upgraded speakers
https://www.cardosystems.com/shop/spirit-hd/
The matching 2nd helmet kit (double check).
https://www.cardosystems.com/shop/freecom-spirit-2nd-helmet-kit/
Most can usually be found at a lower cost elsewhere. Revzilla/Cycle Gear currently has a few coupons floating around that might cover part of the tax or shipping.
@originalben avatar
2012 GTS 300 - Rocinante
@originalben avatar
Have used these for about a year.
Always connect, no dropped signals, good battery life, are comfortable in the ears and don't fallout when removing your helmet- which the previous Skullcandys did and one broke.
https://www.amazon.com/gp/product/B089VVNRF6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Vespa GT200
Vespa GT200
My god they look like they'd hit the center of your brain!!
Vespa GTS 300
Vespa GTS 300
Just discovered, unfortunately not yet tested myself:
Headwave 2.0 motorcycle helmet speaker: https://headwave.de/en/products/headwave_motorrad
Headwave 2.0 uses the helmet as a resonating body to provide a rich sound while riding a motorcycle. Headwave generates sound vibrations, which are transmitted to the helmet shell. The whole helmet vibrates. The result is impressive bass.
⚠️ Last edited by GermanGTSDriver on UTC; edited 1 time
Vespa GT200
Vespa GT200
Heatwave 2.0 uses the helmet as a resonating body to provide a rich sound while riding a motorcycle. Headwave generates sound vibrations, which are transmitted to the helmet shell. The whole helmet vibrates. The result is impressive bass.
Super expensive.
2001 ET4 "Mona"
2001 ET4 "Mona"
I like these! What do you do with the wire running between the earbuds? Just let it dangle around your neck or do you tuck it into the helmet? Also, can you use the mic while you're wearing your helmet?
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Sony SBH56 has worked well for me for over 5 years. It's a Bluetooth dongle, has proper buttons I can use while wearing gloves. It can also let you take operate the shutter button on your phone camera for taking selfies.
@larrymk avatar
Vespa Super 300
@larrymk avatar
Vespa Super 300
I have a uclear system which works great but is a bit pricey. I also have used my AirPods which can be a bit tricky to get your helmet over but if you can, they also work ok, at least in my opinion. The key is to keep the volume low enough to be able to hear what is going on around you. With my uclear I have a chubby button control so I can control them with gloves on, but again all this costs.
@miguel avatar
@miguel avatar
Regarding getting you helmet over the AirPods, I have no problem getting my modular helmet over the AirPods. Open up the chin bar and pull the straps outward. It gives plenty of room to go over the AirPods. And, at least on my helmet, the AirPods fit into the cavity designed for bluetooth speakers so I feel no pressure on my ears.
Miguel
@larrymk avatar
Vespa Super 300
@larrymk avatar
Vespa Super 300
Miguel
I agree I have used my AirPods when my uclear ran out of juice and they worked fine and even with the uclear earpieces they felt ok to me
larry
@cheshire avatar
GTS (sold)
@cheshire avatar
GTS (sold)
What do you consider "reasonably priced" to be?
I've been happy with the base model of either Sena (3S?) or Cardo (FreeComm 1+) and they cost around $90-$100. I have no interest in the comms part, but it's very nice to be able to control my audio without looking. The automatic volume control is wonderful when I turn off the highway onto city roads.
I tried earbuds, but I never could get my helmet on or off without dislodging them, usually painfully.
@gildod avatar
2020 GTS 300
@gildod avatar
2020 GTS 300
I got these and they are reasonably priced.
https://www.amazon.com/Intercom-Bluetooth-Motorcycle-Communication-Headset/dp/B094JY8XBN?th=1
I have not tried them yet, but I have friends who got them and they say for the price they are a steal. So I thought I would buy some, and see how they work.
2001 ET4 "Mona"
2001 ET4 "Mona"
I've been watching this thread with interest. For my purposes, these are the winners! Thanks for pointing them out.
@originalben avatar
@originalben avatar
They are comfortable and the cord just goes on the back of the neck.
Not really sure about the OP's comment about going to the 'center of the brain' as the form follows pretty well established ear plug design.
Vespa GT200
Vespa GT200
I think I found them but can't see how they work with a helmet!
Please show us a picture how you do it?
GTS 300ie
GTS 300ie
You use the Sony Bluetooth dongle with whatever headphones you want. The dongle clips onto your clothes and has buttons.
@armedferret avatar
'23 300 Super
@armedferret avatar
'23 300 Super
I have some JBL Vibe 100 TWS earbuds normally reserved for the gym but if my BT helmet is too low a battery or I only want tunes/GPS in one ear, I'll throw one of them in and it stays in place but is seated deep enough that it doesn't have issues with the helmet going on over it.
properly-sized tips are essential for keeping things from popping out of your ear.
mostly though I just use the Sedici's onboard.
@holx avatar
2018 GTS 300 (12,000km), 2001 ET2 (26,000km)
@holx avatar
Please note that when you use AirPods or other wireless in-ear headphones, that there is a good chance of them falling out while removing a helmet.
I had a similar experience last year where I used a single AirPod to listen to GPS directions while riding, and by the time I reached my destination and parked my GTS, was completely unaware of the AirPod in my ear.
Then I took off my helmet, of course...
I realised what must have happened at the end of the day at home, too far/too late to go back. Never saw that costly little bugger again ...
[ Time: 0.0232s ][ Queries: 4 (0.0037s) ][ live ][ 313 ][ ThingOne ]
