Wed, 03 May 2023 23:18:44 +0000
Wed, 03 May 2023 23:18:44 +0000 quote
One more PX is in queue for its final treatment. Owner is an old friend. This one started pre-COVID as a top end re-bore. He brought me his cylinder to take it to my machinist and the rest of the scooter was getting prepped by someone for a respray, without taking it apart (we call it a splodge respray here). Anyways, cylinder was ready and then he calls me and tells me that the engine looks like it's stuck. Brings me the scooter and the horror!!!
Apparently the guy that was prepping it, wasn't being careful while wet sanding it, resulting in the engine getting seized cause of water. So, he then decided to go for a proper restoration. Engine was overhauled (found him a good used crank) and is waiting on the shelf two years now, since his job got hit by COVID and he was trying to save money for the rest...
Finally, we're reaching the finish line. Frame and "peripherals" were done two weeks ago and everything's on my porch waiting in line...
Updates to come...
Engine...
Wed, 03 May 2023 23:19:01 +0000
Wed, 03 May 2023 23:19:01 +0000 quote
Frame...
Wed, 03 May 2023 23:25:08 +0000
Wed, 03 May 2023 23:25:08 +0000 quote
what's the upper and lower spec limit for the thickness of caked on dirt?
Wed, 03 May 2023 23:27:48 +0000
Wed, 03 May 2023 23:27:48 +0000 quote
Lookin real good!
Wed, 03 May 2023 23:36:34 +0000
Wed, 03 May 2023 23:36:34 +0000 quote
Maybe, max 20mm, min 10mm??
That's the dirtiest I have measured so far...
Wed, 03 May 2023 23:44:16 +0000
Wed, 03 May 2023 23:44:16 +0000 quote
I don't know how you could possibly get that much water inside the motor like that! Looks like the carb cover and filter was off and he used a pressure washer!
Wed, 03 May 2023 23:49:41 +0000
Wed, 03 May 2023 23:49:41 +0000 quote
Hope all that dirt wasn't keeping all the spiders in.
Super nice job on the paint. Props for the tidy seam sealing.
Thu, 04 May 2023 06:47:38 +0000
Thu, 04 May 2023 06:47:38 +0000 quote
No, only the cylinder was out but I'm guessing a hose and TOO much water killed it…
Thu, 04 May 2023 11:40:10 +0000
'74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 - & - '58 AllState '68 Sprint '66(?) Super125 and '72 DanMotor Super150
Thu, 04 May 2023 11:40:10 +0000 quote
EEEK!!! and PHEW!
Good to see that it's now getting the DeLuxe treatment! Lucky scooter...
Thu, 04 May 2023 12:07:55 +0000
Jet Eye Master
PX221 MHR, O tuned PX200, PX181 Quattrini and some motorbikes
Jet Eye Master
Thu, 04 May 2023 12:07:55 +0000 quote
Is it going back together as standard plus? Go faster red makes it look quicker.
Thu, 04 May 2023 14:43:44 +0000
'64 VBB, '74 BMW R75/6 airhead, 1974 Bultaco Alpina 250, Lambretta LI150 project, J50 Special
Thu, 04 May 2023 14:43:44 +0000 quote
The red and the black... maybe your friend could name it Stendahl? It has turned into a bit of a complicated psychological thriller at this point. The motor prep and build looks top notch.
Thu, 04 May 2023 15:30:39 +0000
Thu, 04 May 2023 15:30:39 +0000 quote
Totally stock. Also, autolube was ditched cause the gears were worn and they're now super expensive to replace, only a SIP Road or Polini box in our future plans…
***Now that I looked at the pics again, I think I did a bit of flow work at the rotary, tub & carb. It's been two years…
Thu, 04 May 2023 16:52:59 +0000
bodgemaster
bodgemaster
Thu, 04 May 2023 16:52:59 +0000 quote
Do they make dirt shims?
Thu, 04 May 2023 17:09:03 +0000
Thu, 04 May 2023 17:09:03 +0000 quote
they do: https://en.wikipedia.org/wiki/Unified_Soil_Classification_System
Fri, 05 May 2023 10:57:54 +0000
PX
PX
Fri, 05 May 2023 10:57:54 +0000 quote
What is that for a Red?
Really nice colour and looks fantastic on the PX…
Fri, 05 May 2023 11:55:24 +0000
Fri, 05 May 2023 11:55:24 +0000 quote
If you mean the code, it's MB Jupiter Red, 589. He had seen the first CLA 200 sold in our town and fell in love with it. One stage but it's changing shades with light…
Sat, 06 May 2023 23:05:56 +0000
Jet Eye Master
Jet Eye Master
Sat, 06 May 2023 23:05:56 +0000 quote
Even with stock, more than the inlet can be done. Check the cylinder ports line up with the piston windows.
Increase the base packer size and remove the corresponding amount from the head.
Increase the size of the main jet until it nearly splutters at WOT.
Probably a few more things, I'll edit if I think of them.
Sat, 20 May 2023 20:26:08 +0000
Sat, 20 May 2023 20:26:08 +0000 quote
Started work on it. Refurbished the loom, new green "kill" wire, rear shock painted by me (we forgot about it). Legshield trim and one side of rails are done...
Enough for today...
Sat, 20 May 2023 21:39:44 +0000
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
Sat, 20 May 2023 21:39:44 +0000 quote
So juicy colour!
I'm already can't wait when I get back my P from the painter and start to do the same.
Sat, 20 May 2023 23:05:06 +0000
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate
Lucky
Sat, 20 May 2023 23:05:06 +0000 quote
POP RIVETS??? YOU USED ***POP RIVETS*** ON THE FLOOR RAILS???
That's it. You're now dead to me.
Sun, 21 May 2023 01:40:03 +0000
PX 200
PX 200
Sun, 21 May 2023 01:40:03 +0000 quote
Lol… pop rivets.
But actually, didn't the PX have pop rivets on the first row, off the factory floor?
I see it all the time on PXs. Can't be a coincidence.
Sun, 21 May 2023 02:44:11 +0000
Sun, 21 May 2023 02:44:11 +0000 quote
Actually, later PXs came with pop rivets and closed end caps from factory, so everything's correct for the period (it's a 1996 model)…
What is not correct is the graphite GTS Vespa badge but that's what the owner wanted…
Sun, 21 May 2023 02:52:27 +0000
LML 125 4t & LML 200 4t
Sun, 21 May 2023 02:52:27 +0000 quote
Congratulations on a thorough job very well done! Great photographs too. I always find it quite fascinating to see a scooter taken down to its component parts then reassembled - rather like working in the Vespa factory!
Sun, 21 May 2023 03:22:58 +0000
'77 P200e (Maggie May)
Sun, 21 May 2023 03:22:58 +0000 quote
Scooter Mercado has the replacement gear. Part number 221614. $156.00 kinda pricey.
Sun, 21 May 2023 12:24:08 +0000
125 TS VNL3
125 TS VNL3
Sun, 21 May 2023 12:24:08 +0000 quote
nice work mate. i also dont like either pop rivets. cant wait to see it completed
Sun, 21 May 2023 12:49:33 +0000
Sun, 21 May 2023 12:49:33 +0000 quote
Guys, like it or not, pop rivets are correct for the production year. And there's no other way to mount the closed end caps…
Also, it was a speedier and more efficient way down a production line…
Sun, 21 May 2023 13:05:55 +0000
Lucky
Lucky
Sun, 21 May 2023 13:05:55 +0000 quote
SaFiS wrote:
Guys, like it or not, pop rivets are correct for the production year. And also, there's no other way to mount the closed end caps…
I know, but I can't help myself. They just feel "wrong" to me on a shifty bike, even when they're correct.
Sun, 21 May 2023 18:18:01 +0000
Sun, 21 May 2023 18:18:01 +0000 quote
Seems that all P and PX have pop rivets on the ends of the rails. Same as PK pre-XL models.
Sun, 21 May 2023 18:38:18 +0000
Sun, 21 May 2023 18:38:18 +0000 quote
The early P (pre PX) had normal rivets through plastic end caps. I normally replace those with socket head screws.
I also see no shame in pop rivets, even in cases where it is not "correct".
Sun, 21 May 2023 18:40:40 +0000
Sun, 21 May 2023 18:40:40 +0000 quote
My 1981 P150X have pop rivets. I can't be sure for 100% that it was original, but seems so.
Mon, 22 May 2023 20:07:23 +0000
Mon, 22 May 2023 20:07:23 +0000 quote
Bit more progress...
Mon, 22 May 2023 21:22:43 +0000
Mon, 22 May 2023 21:22:43 +0000 quote
Just plain ol outstanding work! Can't wait to see it done!
Tue, 23 May 2023 02:47:24 +0000
Vespa
Vespa
Tue, 23 May 2023 02:47:24 +0000 quote
Looking fantastic and accept rivets over nuts and bolts any day all day, carry on.
Sat, 27 May 2023 18:59:50 +0000
Sat, 27 May 2023 18:59:50 +0000 quote
Time for an update, lots done during the week. Main loom in, cables in, fork link assembled, new bearings everywhere, new original centre stand with dual spring setup, modified the side stand so it won't hit the floor anymore and today it's fully on its feet...
Lots of photos following...
Sat, 27 May 2023 21:19:13 +0000
Sat, 27 May 2023 21:19:13 +0000 quote
Hellz yeah!! Lookin good!
Sun, 28 May 2023 21:45:47 +0000
Lucky
Lucky
Sun, 28 May 2023 21:45:47 +0000 quote
That is some seriously beautiful work right there.
Sun, 28 May 2023 22:13:04 +0000
Sun, 28 May 2023 22:13:04 +0000 quote
Nice. As always.
Sun, 28 May 2023 23:00:03 +0000
Jet Eye Master
Jet Eye Master
Sun, 28 May 2023 23:00:03 +0000 quote
Surely better than it was new
Thu, 08 Jun 2023 22:12:32 +0000
Thu, 08 Jun 2023 22:12:32 +0000 quote
Getting there. Lots of time spent in cleaning parts that are going to be reused and reconditioning looms, wires, etc. Hoping to finish it in the weekend. Engine's in, electrics done battery side. I always add an extra ground wire from battery to frame / regulator since Piaggio stupidly grounds the whole loom through the stator using the starter's ground wire bolted on the engine. If that breaks, nothing battery related works. Front indicators done (smoked lenses with amber bulbs), handlebar mounted with the new allen bolt that Piaggio now uses (OEM code: 655554), cowl levers in, helmet hook mounted and made me a rubber grommet for the fuel gauge wiring (story at the link below)...
Crap made by Grabor
Pics...
Thu, 08 Jun 2023 23:39:12 +0000
parallelogramerist
parallelogramerist
Thu, 08 Jun 2023 23:39:12 +0000 quote
It's looking pretty darn sweet Safis! I'm SUPER impressed that you're replacing the fork link bearings after the painting! That definitely takes a high skill level!! Right now i'm contemplating on replacing my fork link bearings on my PK fork before or after painting. It would be really difficult to press everything together without scratching the paint.
  DoubleGood Design
[ Time: 0.0493s ][ Queries: 3 (0.0256s) ][ Debug on ][ 298 ][ Thing Two ]
