@jackie_f avatar
2024 Vespa Sprint
@jackie_f avatar
2024 Vespa Sprint
Hello!
This has happened to me twice in 8 months. I hit a pothole and the bike's motor dies on me. The dashboard is still on. To get running, I used the key to turn it off and on.
This time, when I was able to go, I could smell gas but I'm chalking it up that I was going up a steep hill.
The common denominator for both is potholes, but not just any pothole. Unfortunately, I don't know which potholes will cause this.
Has anyone else experienced this?
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
My first thought is a loose connection that only an impact reveals. As to which connection is the cause, more knowledgeable than me will chime in shortly.
@jkj-fz6 avatar
@jkj-fz6 avatar
The potholes you hit. Try to avoid them.
Seriously, which of your scooters does this happen with?
Could be the spark plug wire is loose. Or, the bump might be pinching a wire or a hose. That's why the model of your scooter matters. Some have known pinch points that often cause problems.
PX 150 and GTS 300 HPE Super Tech
Perhaps you jarred a tipover switch hard enough that it killed the engine
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
That's what I was wondering and it's why I hate safety features on bikes.
When I was a student my ex gf and my best friend both had Honda CBR125Rs, both would cut out on them on the highway if they hit a bump. We eliminated the kick-stand safety switch that would kill the motors if the side stand went down while the bike was in gear. No more bike cutting out after big bumps.
We need to know which bike it happened on.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
I remember another member having a similar problem. It was caused by a short spark plug wire. When a big bump was hit, the suspension would compress farther than usual and the spark plug wire would stretch causing the engine to cut off.
⚠️ Last edited by caschnd1 on UTC; edited 1 time
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Possibly dodgy kill switch, loose ignition/key, loose battery connection.
Or spark plug boot or HT wire connection at either end.
@oldschooot avatar
@oldschooot avatar
caschnd1 wrote:
I remember another member having a similar problem. It was caused by a short spark plug wire. When a big bump was hit, the suspension would compress farther than usual an the spark plug wire would stretch causing the engine to cut off.
Yep.
Follow this up.
@obx_dude avatar
@obx_dude avatar
Wanted to chime in and say how helpful this forum is. The wealth of knowledge is quite impressive!
with all the abuse of my bike that I've done on very bad roads and stupid speeds, the tip over switch has never caused the engine to stop with out me actually dropping the bike. Seems to be very safe in this regard.
also my kill switch recently became really problematic BUT it did not stop the engine unless I was idling and then it would often stop me starting it again (red kill light often remained on for several seconds). never killed it when moving - suspect the ecu might ignore it when moving. thorough clean with electrical parts clean has fixed it for now.
so I strongly doubt those two suspicions mentioned above.
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
That was my first thought as well.
I'd cracked an injector apparently from contacting the pet carrier on a bump, though that's unclear as it wasn't recent to the engine dying. This was my GTS, so YMMV depending on the bike.
@jackie_f avatar
2024 Vespa Sprint
@jackie_f avatar
2024 Vespa Sprint
Thank you, everyone! My bike is a 2019 Primavera 150 Sport.
@rrider avatar
@rrider avatar
Mine too.
About the comment
' To get running, I used the key to turn it off and on. '
Just to clarify: the engine cut off. After this, you turned the key to off, then back to on and then pressed the start button?
@fleece avatar
@fleece avatar
Since 12th October 2005
@jackie_f avatar
2024 Vespa Sprint
@jackie_f avatar
2024 Vespa Sprint
RRider wrote:
About the comment
Correct.
@rrider avatar
@rrider avatar
Oh, and good starting point is of course to check that the spark plug cap is not loose. This would probably give other symptons too, but at least it is easy to cross over from the check list.
The very early modern Primaveras/Sprints had the habbit of cutting off randomly, mine was among these. Can't remember anymore what was the root cause, but it was fixed at dealers as a warranty fix and troubled only early models. So should not have anything to do with your scoot (in the case you stumble on such stories in the web). Also, it did not have anything to do with bumps
@amateriat avatar
@amateriat avatar
Same here, after hitting a crater with Melody (GTS #1) in Brooklyn a few years back. Thing was, the failure didn't completely "take" until a few months later, while on my way into Gotham via the New Jersey Turnpike, precisely the place you don't want your engine to suddenly cut out. Not saying that's the OP's issue here, but it wouldn't hurt to have the injector body looked over.
@cheshire avatar
GTS (sold)
@cheshire avatar
GTS (sold)
OP: Did you need to turn the key off and back on or is that just a step you took? Asking because that's usually needed to reset the computer components (fuel pump, immobilizer, safety switches, ecu, etc) instead of mechanical (wiring, spark plug... you get the idea).
Have you tried, when it happens, just holding the brake and starting it without touching the key?
vespa gts250
vespa gts250
Had something similar to that with my bike, wasn't potholes it was rain too. If the bikes old and you drive it in all kinds of weather that engine cut off switch gets really really sensitive. Brought it into a mechanic like 4 times cause it would cut out temporarily at highway speeds and die when it was going under 40. One day I just lightly tapped the switch just put a tiny shock on it and that was it, was able to get the bike to cut out over and over again. It's a 2 dollar part too and sorta easy to put in
2020 Piaggio Liberty S 150, 2016 Vespa GTV300ie, 2009 Yamaha C3
I hit an awful pothole with my 2016 GTV last summer, the EFI/ASR light came on and the scoot immediately started running like garbage. I pulled over, turned it off and back on; the light went away and the scoot was running fine again. However, the EFI/ASR light started coming off and on intermittently over the next month, without any noticeable change in how the scooter was running.
My friend took a look and tinkered with the ASR sensor; it wasn't gapped properly. I assume hitting the massive pothole jarred it enough that is now JUUSSSSTTT out of the proper alignment-- it's not so "off" that it limits the throttle, but it's "off" by enough that it trips the sensor and the light comes on periodically.
[ Time: 0.0083s ][ Queries: 3 (0.0023s) ][ live ][ 313 ][ ThingOne ]
