@gatekeep avatar
1974 Rally USA 200 1980 P200e
@gatekeep avatar
Hi does anyone have the secret for fitting/reinstalling the air bellows ?
Yes,
I find these invaluable, especially #3, Captain Hook.
@qascooter avatar
@qascooter avatar
I just documented this for lucky bear...
https://modernvespa.com/forum/post2605967#2605967
@autojack avatar
'76 Vespa Rally 200
@autojack avatar
'76 Vespa Rally 200
Yeah you need some kind of tool you can hook under it. I've used a bent piece of spring steel before. Now I have pick tools like someone showed above. It also helps to warm it with a hair dryer or heat gun or just leave it out in the sun. Softens the rubber. I've also sometimes found it easier to put it on the frame first, working from inside the bellows, and then hook it over the carb.
parallelogramerist
parallelogramerist
a quick shot of silicon spray will help a bunch.
*EDIT: i just looked at QaScooter's quick tutorial (great pics Scott) and i do it the exact same way as well.
⚠️ Last edited by whodatschrome on UTC; edited 1 time
@fatbear5 avatar
1977 P200, 1980 P200
@fatbear5 avatar
Yes, listen to gascooter. It was his advice that made it work for me.
Lucky bear
⚠️ Last edited by Fatbear5 on UTC; edited 1 time
@oopsclunkthud avatar
3:5
I use the same method, no other tools
@autojack avatar
'76 Vespa Rally 200
@autojack avatar
'76 Vespa Rally 200
Just occurred to me to ask: what is the point of the bellows and connecting the carb air intake to the chamber under the seat? The only thing I can think of is getting cooler air from being a little further from the motor, but I'm doubtful that's it.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
I did it so It would be harder to pickup any large chunks of dirt or road debris.
px 125 disc
px 125 disc
The idea seems to be that a) its cool air rather than hot air from around the engine ( cool air good ,hot air bad and b), it acts as a primary filter, a settlement chamber if you like. This idea is used a lot elsewhere, for example the filter on my fish pond has one and the muck that settle there you wouldnt believe.
parallelogramerist
parallelogramerist
Ride 100 meters down a dusty gravel road with no air bellows and you will be absolutely amazed just how dirty your air filter will be.
@autojack avatar
'76 Vespa Rally 200
@autojack avatar
'76 Vespa Rally 200
It makes sense I guess, I'm just surprised that taking the air from under the seat provides that much more filtration of particles. But maybe the occasional methane emission boosts performance a bit...
[ Time: 0.1545s ][ Queries: 3 (0.0750s) ][ live ][ 313 ][ ThingOne ]
