@whereshaldo avatar
Stella 2T 150, Honda C70
@whereshaldo avatar
I'm putting my VBA engine together and there is a good bit of movement at the clutch. The lever on the engine that engages the clutch moves about 3/4 of an inch before a hit resistance. This seems wrong to me and I don't want to put the engine in until I figure out if this is correct or not.
It's a newly rebuilt clutch, new springs new clutch material.
In comparison my Stella only moves about 1/8 inch.
Thoughts?
Hal
@ray8 avatar
@ray8 avatar
Pretty sure that's correct. 35 or so degrees of rotation before clutch spring (hard) resistance.
@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
^^^^ Concur.
See 17:50.
@whereshaldo avatar
@whereshaldo avatar
I was using one of the fancy sip clutch bushings and it's ever so slightly shorter than the stock bronze ones. I swapped in the bronze one and am much happier.
ymmv
Hal
[ Time: 0.0102s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
