Sun, 07 May 2023 21:23:27 +0000
Lx 150 3v
Lx 150 3v
Sun, 07 May 2023 21:23:27 +0000 quote
Love the bike but nervous breakdown waits at the corner
9months owning lx 150 I 3v 2013 After service of 20.000 km including ALL needed (o rings,filters,valves,belt etc -mechanic said everything needed replacement and replaced ) bike runs way smoother BUT STILL .
1.cuts out when stopped 1 maybe two times in an hour city ride at red traffic lights(service didn't help to fix that problem).
2 .Radomly and rare more often when cold and 2 passengers on it stucks for 2-3 seconds when accelerating and after all OK (a problem that service solved at 90% but exists rare and less time stucked. it was 2-4 second stuck and not rare now its 1-2 seconds and rare BUT STILL THERE
3.Excaust pop//bang sound when from high Rev to low not always but not rare and more often when hot.
Mechanic is not a specialized vespa tech but repairs Kawasaki Suzuki Honda Yamaha piaggiov owns a gts 250 But after service exaust pops here and there which wasn't happening and engine cutouts at idle remains and no complete solution for mufle 2 seconds when accelerating tells me no special knowledge deeper at details.....
ANY SUGGESTIONS THAT will help what to check would be helpful to a new mechanic I ll visit
Thanks.!!!!
Mon, 08 May 2023 01:05:04 +0000
1952 allstate (early), 1958 allstate, 2009 S150, 2001 ET2
Mon, 08 May 2023 01:05:04 +0000 quote
Any check engine light or anything? This is a fuel injected model right?
Mon, 08 May 2023 03:53:25 +0000
Mon, 08 May 2023 03:53:25 +0000 quote
Acceleration from a a standstill or at speed (roll on)?
What is your level of handyman skill?
So the idle speed is a bit low and it pops and bangs during deceleration?
Hmm? There is an air leak in the inlet.
Mon, 08 May 2023 20:22:05 +0000
Lx 150 3v
Lx 150 3v
Mon, 08 May 2023 20:22:05 +0000 quote
From low speed 10-20 km/h and sudden full throttle.
Theoretically I understand bike parts and interaction but hands are a different story.Reason of asking is to minimize another technician fault.😀thanks
Tue, 09 May 2023 03:13:22 +0000
Tue, 09 May 2023 03:13:22 +0000 quote
Also could be that the throttle body/throttle position sensor needs a squirt with some carb cleaner?
Thu, 11 May 2023 01:40:39 +0000
Thu, 11 May 2023 01:40:39 +0000 quote
Bung some fuel system cleaner into the gas tank and run around for a week.
May not solve it but it won't do any harm.
⬆️    About 18w elapsed between posts    ⬇️
Sat, 16 Sep 2023 17:59:16 +0000
Lx 150 3v
Lx 150 3v
Sat, 16 Sep 2023 17:59:16 +0000 quote
After replacing sensor L ,air fuel line,Beck that sprays gas i STILL have less rear mostly snifs than pops when iiding down and reopen A Litlle the throttle,only a little when full no snifs.Valve clearance OK,parts of injection cleaned etc.What makes the snifs not diagnosed even atg pisggio dealers software computer.
Any help what to look for further???
  DoubleGood Design
[ Time: 0.0260s ][ Queries: 4 (0.0043s) ][ Debug on ][ 286 ][ Thing Two ]
