LX150 2006
LX150 2006
2006 LX 150
Replaced LH Brake lever for stripped mirror mount. Since then, electric issues.
Kill switch does not shut off motor, but Motor will not start with kill switch off.
LH Turn Signal works fine.
RH Turn Signal solid ON. Shows on on speedometer display. Both front and back lights on solid.
Never had any issues. Thoughts. Turn signal Relay? Faulty turn signal switch?
GT 2.4
GT 2.4
How much did you take apart to replace the perch?
LX150 2006
LX150 2006
Bare minimum but you have to crack the perch open to remove brake lever. Tropened to double check connectors. No help
[ Time: 0.0088s ][ Queries: 3 (0.0031s) ][ live ][ 313 ][ ThingOne ]
