@pinball avatar
GT200 Granturismo 2006
@pinball avatar
My 2006 GT200 had been perfect in the reliability department until a couple days ago. The vintage green stunner kept dieing when I'd come to a stop. Fortunately, she'd start up and off I'd go. Then, driving at 35 mph she slowed down and died for good.
Here are some pictures after I pushed her back to my work. There is a mysterious vacuum line that I can't see where it's broken off from, but it may be the cause of the problem. Thoughts? I ordered a new Tygon fuel line and filter and fuel pump and hope that will address fuel delivery.
@greasy125 avatar
@greasy125 avatar
that's part of the evap system. the red/white thing is a one way valve that's between the canister and the intake tract. basically what you have going on is a massive vacuum leak.
you can refresh the hoses, and be fine. or you can cap off at the manifold/T where it goes in and be fine. or you can eliminate the entire evap system.
@vintagescooterdude avatar
2006 GT200 2009 Genuine Stella
I would hardly call a 2006 "vintage". To me, to be vintage, something like a motor vehicle would have to be at least 50 years old. I have a 2006 GT200 just like yours, including the Scooterwest sticker. I was going to remove the entire evap system, but there were a lot of parts that were very difficult to get to. So I just disconnected and plugged everything.
The GT200 was made with both Keihin and Walbro carburetors. Fortunately yours has the Keihin. The only place I've ever seen anything made by Walbro is on landscaping equipment, like weed whackers. I had my carburetor out once, and discovered that there are two small coolant lines that connect to a fitting on the bottom of the float bowl. I'm assuming this was done to warm the float bowl. Totally unnecessary in AZ. I removed both these small hoses, and with a new piece of hose, just made a loop out of it, bypassing the carburetor. There appeared to be a tiny bit of corrosion where one of them connected to the float bowl. I bypassed the carb with this hose to prevent a possible future leak, and to make the carburetor much easier to get out. If your hoses are starting to deteriorate, you might want to take a look at that one.
@aiosi avatar
@aiosi avatar
If it is the same Green as my 2005 PX150 Serie America, the color is called "Verde Vintage".
So yes, it would be called "vintage" as long as you qualify it with "green". Razz emoticon
@pinball avatar
@pinball avatar
Vintage green is the official translation of the Italian color code name, so I didn't presume the 2006 date made it vintage. Hope there's no hard feelings there.
The blue line hose in the picture is loose and sitting there, that's the mystery. It has broken ends and I don't see where it broke off from.
If anyone who owns a 2003 to 2007 GT 200 could take engine pictures and send them my way, I would appreciate that. I'm a visual learner.
As for plugging all the vacuum lines, I guess I could try that, but the britteness issue remains on the hard to reach ones. I'd need to understanding how to remove/plug the main vacuum line.
@abner_bjorn avatar
@abner_bjorn avatar
If your fuel and vacuum lines are original, take this as a sign to replace them all. If you yank out the EVAP system while you are doing this, you'll shed some weight and use a lot less 3/16" line. Look into blocking off the SAS while you are at it. You won't recognize your scooter at idle if you do.
@crackedegg avatar
2018 Vespa GTS300
@crackedegg avatar
2018 Vespa GTS300
I thought only fuel injected bikes have to be capped off and that carburetor bikes were not capped?
@greasy125 avatar
@greasy125 avatar
they all use a port on the manifold to recover fuel vapor, it's just in a different location and size depending on the flavor.
the easiest way to defeat the system is to merely plug it at the manifold port and just leave everything else be.
some people feel the evap. must be vanquished, ripped from the machine, brought forth and demanding it answer for all the injustice and running problems it could have conceivably caused.
but, that's like, a lot of work man. just cap it and get on with your day.
@greasy125 avatar
@greasy125 avatar
do you have a workshop manual? if not, it'd be a great idea to get one. there is a ton of pictures and info in there on the evap system.
anyway, you're only plugging one vacuum line. it's not a big deal.
I'll grab a pic and post it up when I get back to the shop later.
@greasy125 avatar
@greasy125 avatar
here's the evap line
the 1/4" line directly above is is vacuum for the fuel pump. the line next to it in the sheath is evap that connects to the bowl vent for the carb (you can see it up next to the diaphragm cap). the smaller 3/16" line further over to the right that is partially obscured by the screwdriver is vacuum for the SAS system.
from there it ducks down the front (into spider city)
then jogs over to the left and up into the cowl section (past spider suburbs)
it emerges out from under there (that's the roll over valve in white)
and shoots up to the tank neck where it T's in
underneath the cowl section is where all the evap crap lives, you can see the attaching nuts on the bracing in the pics.
how much you want to repair or remove is your call.
to familiarize yourself with the components of the system there is a diagram on page 70 of the FSM [7.13 evaporative emission system]
I was going by the year. I didn't know the name of the color. Some of the hoses have been moved around in mine, and are no longer in the original location. The main thing is to find and plug the vacuum leak. It will be on the carburetor or intake manifold. It may just be a vacuum fitting, or there may be a hose connected to it. If it will start at all, you should be able to hear the vacuum leak with the engine running with the pet carrier removed.
EDIT: Ok I just checked mine. The first picture posted by greasy 125 with the red screwdriver is it. The hose that goes up is the one for the vacuum petcock, the one that goes toward the front of the scooter and into the sheath is the evap line. You don't need to worry about the rest of the system. My hoses were fine. I just cut that one a couple inches from the intake fitting, and screwed a small bolt into the 2" piece. A better fix would be to remove the hose at that fitting, and put the proper size vacuum cap on the fitting. You can find them at any auto parts store.
GT200
GT200
2004 Vespa GT200L
2004 Vespa GT200L
No idea what that blue hose is from or goes to. I sent you a PM with a bunch of my pictures taken during the process of replacing the lines between my engine and charcoal canister. I was having a nearly identical issue to you with the 2004 Vespa GT200L I bought last month. Originally the issue was that warm starts were taking 15-20 seconds to start up. I had the mechanic from the shop I bought the Vespa from take a look at it and he leaned out the mixture and that's when the loss of powers would happen around 45mph and then a stall when I came to a stop. Not to mention, the entire time I had these issues, my fuel economy was absolute garbage. I went from a full tank to 1/4 tank in roughly 50 miles. I ended up replacing the hoses and haven't had the issue pop up again in a week.
Hope you were able to figure out your issue. Personally if you don't want to plug up the vacuum line, I'd look into replacing the charcoal canister entirely to return the scooter to it's original state.
[ Time: 0.0123s ][ Queries: 4 (0.0062s) ][ live ][ 313 ][ ThingOne ]
