Elettrica
Elettrica
So I just got done changing the hub oil on my Elettrica and I can't get the service message to go away. I've tried the 3 presses,
1. Half sec,
2. 2 sec,
3. 10-15 sec
and it won't go away.
Also there is a warning indicator I don't recognize. It's the yellow one below the plug icon. It looks like the kick stand, but that doesn't make sense.
Any help is much appreciated!
Instrument cluster
Instrument cluster
@jakem avatar
Vespa Sprint Sport S 125cc
@jakem avatar
This isn't the normal service notification, this is a major warning that sometimes won't let you start the Vespa.
The Vespa Elettrica has 3 or 4 computers that need to be updated by a dealer as part of the servicing. This is the majority of the servicing work that is done to the elettrica.
When I had mine done, I was given printouts of all the updates (there were a lot!). These can't be done manually at home, and are likely to be the problem.
You are correct in that the other warning symbol is stating the kick stand is incorrectly down.
Sort out the kick-stand switch problem first, as this alone might be the problem preventing normal operation.
[ Time: 0.0147s ][ Queries: 4 (0.0090s) ][ live ][ 313 ][ ThingOne ]
