@rossodragongts avatar
2013 GTS300ie Super
2013 GTS300ie Super
Hello, Started my 2013 GTS300ie Super up the other day, after a few minutes, noticed a plume of white smoke coming up from under the right side of the engine, no oil, rubber, or plastic smell. At first look, couldn't find anything. Started up this morning with the underseat tub out, flashlight in hand, and determined that the smoke was coming off of the Lamda Sensor. The sensor and the whole area around it are all clean and dry, no oils or anything. Curious if anyone else has had this issue? Also curious about checking the sensor with a multimeter, resistance test maybe, but don't know what the ohm value should be. Any knowledge you may share is appreciated, thank you.
Oh dear... The lambda sensor provides a voltage (normally between 0.2V and 0.8V for lean and rich respectively) and you can't test it directly by measuring its resistance. Also the input to the ECU should be high resistance. So either the ECU has a major fault (unlikely) or the wires to the sensor have somehow been shorted to somewhere they shouldn't. I've heard of that before, but not of the sensor actually smoking.
2013 GTS300ie Super
2013 GTS300ie Super
Thank you for the reply!
@waspmike avatar
@waspmike avatar
There's nothing in the construction of an OE oxygen sensor that can produce smoke.
Therefore something has contaminated it. Roadwater [white steam] coolant [white smoke] or oil [blue-white smoke.]
I also suspect some contamination of the lambda (which may just burn off causing no harm)
do you get a check engine light on your dash?
2013 GTS300ie Super
2013 GTS300ie Super
Check engine light goes off when the engine starts.
2013 GTS300ie Super
2013 GTS300ie Super
Smoke is white, might just try riding a few miles around the neighborhood to see if it stops smoking.
@greasy125 avatar
@greasy125 avatar
is it possible you have a little teeny tiny coolant leak? the lambda and headpipe would be right in the direct path there...
2013 GTS300ie Super
2013 GTS300ie Super
I looked, and felt the sensor, the exhaust, the wires out of the sensor, and was observing it right after starting the engine. No coolant, oil, or anything on or near the area.
2013 GTS300ie Super
2013 GTS300ie Super
Well, went for a two or three mile ride, all cleared up!!
[ Time: 0.0110s ][ Queries: 3 (0.0027s) ][ live ][ 313 ][ ThingOne ]
