1968 Sprint 150
1968 Sprint 150
My speedometer just stopped working last week. If it's the cable that needs to be replaced is there other stuff around it I should replace?
@markosmarkos avatar
Other possibility is the driven worm gear at the hub where the cable starts. The driven gear is plastic and can wear out or strip. Especially if the cable hasn't been lubed in awhile, it will start to bind. The cable will twist and break, or the plastic driven gear will strip.
1968 Sprint 150
1968 Sprint 150
splash_wave wrote:
Yes, they are pennies. Hook yours out and see if its mangled. One thing you might want to check is that the speedo headset end hasnt popped off. I have a px125 2003 and the other week mine stopped and the white plastic clip that holds the outer cable and inner had popped off the actual speedo itself. I took the headset off last year to replace a headlight bulb so maybe I hadnt locked it completely in place to the headset speedo unit.
https://www.sip-scootershop.com/en/product/speedometer-drive-gear-12-teeth_94430000?cr=3a6304bb-cc81-4ed5-9f63-1ff45fe1abfa&gad=1&gclid=EAIaIQobChMIyOC8hLj3_gIVwrLVCh37aA4oEAQYASABEgKnY_D_BwE
Headset end is white, mine worked loose as the lugs not clipped into speedo unit, hence stopping
1968 Sprint 150
1968 Sprint 150
Where the drive gear is on the front wheel is there some nuts and bolts I have to take off to get to it?
@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
Here you go.
1968 Sprint 150
1968 Sprint 150
thanks
1968 Sprint 150
1968 Sprint 150
What does the thing that looks like this ♂ do? The silver one with the nipple.
@garncarz avatar
@garncarz avatar
Grease fitting
1968 Sprint 150
1968 Sprint 150
OK that means the speedo drive gear needs oil to not destroy itself?
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
Grease, not oil. So yes.
@scooterist avatar
@scooterist avatar
Put one of the center stand legs over a 2"by 4" wood piece. Remove the speedometer, detach the cable from the speedometer and with your hand or leg make the front tire roll. You should see right of way if the cable rotates.
If the cable rotates then it could be :
1) The cable wasn't properly making contact with the speedometer
2) The speedometer is not working.
As far is the bottom part. Yes, there is a gear or two by the hub, I thin k one of them is a worm gear. A common problem with the old scooters is the cable fraying internally on the inside. If that happens the you get erroneous speed readings ie: like it works just fine up to 30 mph then you keep accelerating but the speedometer seems to barely move after that then it picks up again.
[ Time: 0.0167s ][ Queries: 4 (0.0087s) ][ live ][ 313 ][ ThingOne ]
