gts 250ie
gts 250ie
hey guys need some help my vespa gts250ie starts but dies when you give fuel and wont stay running for more than 15seconds
one more thing to add is that the bike was running fine before,before this happened, the fuel tank was filled up full
here is the video
https://youtube.com/shorts/0umnZoJFdMA?feature=share
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Smarter people, is vapor lock a possibility here?
OP - Open up the tank cover, rock it back and forth. Take a cone put it over the opening, take a deep breath in (away from the cone), and exhale hard into the cone.
Vespa GTS SS
Vespa GTS SS
I know this has been more than a week but I think this could be caused by flooding the evap canister during a gas fill up over flow. Heard Robot mention this exactly in a video he done.
^^^ this. Disconnect the suction line for the evap system at the intake manifold and cap it off and see if that helps. Also check the state of the manifold with a small mirror all the way around for cracks while you are there.
gts 250ie
gts 250ie
did you guys see the video by chance
2009 Vespa 250ie GTS
Following! My 2009 250ie just started doing the same exact thing today. I put new injector in, checked spark plug, compression, voltage is showing 13.5VDC.
I am a bit bewildered as to what the problem is.
[ Time: 0.0086s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
