@basile_bailey avatar
VBB
VBB
Only recently got my restoration project VBB finished and on the road, and after several very local test-rides I was starting to conclude I had ironed out most of the bugs. Sunshine convinced me it was time to drive it to work and then to an afternoon meeting (a round trip of about 20 miles). Within the first mile I discovered I was getting a tremendous amount of front end rattle and banging when I was riding over even the most mildly uneven surface. The shock is new, but it was as if I had no shock and barely a damper, so I stopped to check for something obvious that was loose. I couldn't find anything but decided to check the whole front end set up in close detail when I got home.
After my meeting wrapped up I turned left out of the parking lot but half way through the turn the front wheel stopped responding to my steering and instead pulled sharply to the right, so I slammed into the curb and the scooter skidded over on its side onto a grass verge and the sidewalk. Although the headset bolt was torqued to spec (as recently as a week earlier) it seems like somehow it worked loose. Fortunately I wasn't going very fast, and a couple of strawberries and a wrenched thumb are the extent of my injuries. I am _amazingly_ fortunate this happened on a side street at low speed and not when I was on a four lane road at 45mph on my way there.
After letting the scooter sit for a week I hammered out the dents in the legshield and right cowl this weekend and started wondering where I can source an original right-side cowl trim, as mine is toast. But more pressingly I need to figure out what was up with the front end and how the fork got to have a mind of its own, independent of the headset. If you have ever had this experience you will know the feelings it provokes are not good.
Any suggestions for securing the headset? Any ideas about what the source of that rattle/banging/vibration in the front end could be (fork and races are properly adjusted)? Any suggestions how to test the shock/damper/suspension?
@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
First off, glad you are OK. Check the torque on these guys?
For my Allstate, I torque the bottom nut to 15NM, install the lock washer, torque the top nut to 60NM, back off the lower nut against the upper by 90 degrees with a hook wrench. Bob's your uncle. Someone check my numbers.
https://www.scootermercato.com/Scooter-Parts/Factory-Tools/BU5420
https://www.sip-scootershop.com/en/product/steering-head-bearing-wrench-sip-universal_90127950?q=wrench
VBB
VBB
Thanks Garncarz, thats very helpful. I haven't ever had a torgue wrench on those nuts, as I thought they were supposed to be tightened according to how free the fork bearings are when turning the handlebar left and right. I snugged the lower one until the bearing was binding a little (would not fall away to one side under gravity), then tightened the upper one down on it, and then I backed the lower one off a hair.
@chandlerman avatar
Lucky
72 Days Since Last Explosion
Lucky
@chandlerman avatar
The fork retaining rings being loose wouldn't cause the headset to spin loose. If they're loose, it usually causes a really bad shudder in the front end when you brake.
I'd look at the headset retaining bolt. More specifically, make sure it's the correct bolt so it has enough thread to adequately tighten it down. It also needs all three washers: a flat washer under the head, then a flat washer and a lock washer under the nut.
And you'll need a pair of sockets (I think 15mm, but maybe 14mm--someone check me on this one) to get it properly tightened down.
As to the wrench for the fork rings, I have the buzzetti version and then I cut out the section between two of the teeth so I can use it on a headset with the cables & wiring in place. I highly recommend that mod.
parallelogramerist
parallelogramerist
That's more or less how i tighten up my headset bearings as well. The lower nut by feel and then the upper nut with a torque wrench.
@markosmarkos avatar
Any possibility the pinch part in the headset has cracked and therefore cannot be tightened any more?? Seen it once.
px 125 disc
px 125 disc
That happened to me when some scroat tried to nick my px by yanking on the handlebars to break ( unsuccessfully)the steering lock.
Worth checking
@qascooter avatar
@qascooter avatar
chandlerman wrote:
I'd look at the headset retaining bolt....
^^^THIS^^^
@subetherbass avatar
I find that the bearings "settle" and everything comes loose a while later (in relation to up n down movement and shudder).
For the bolt... I stand in front with wheel between legs, wiggle handlebars till things seem straight, tighten nut... wiggle bars, and if it still moves, tighten it more... once it don't move, go for a ride, see if it goes straight, but more importantly, if the bars are even distance from you and your arms feel even..................
Then readjust and start the process again................
And again.
Then, after riding a bit, recheck.
[ Time: 0.0109s ][ Queries: 4 (0.0048s) ][ live ][ 313 ][ ThingOne ]
