px 125 disc
px 125 disc
Looks like the rear brake oil seal has gone on my 2003 px 125.
Two questions .
1) Firstly do I have to split the cases to replace it? if so......
2) This post ( Info: Inner vs outer rear hub oil seal )I can just put in an external seal, is this possible? if so, what seal? is it special?
Thanks for any input
@roland87 avatar
'13 LML Star 200, '81 50 Special, '81 P 150 X, '87 PK 50 Nuova, '84 PK 50 S
@roland87 avatar
You don't need to split cases. Just remove felt ring and put seal there.
I done it few times on PX 125 near 2000 year and Cosa 2 200
The external seal for PX was 31*47*7 and 32*47*7 for Cosa.
I also use bearing with rubber(?) seals for example SKF 2RSH.
PX 31*47*7
PX 31*47*7
Cosa 2 200 32*47*7
Cosa 2 200 32*47*7
px 125 disc
px 125 disc
Thanks for that info, means I can sleep easy tonight 😁
@orwell84 avatar
@orwell84 avatar
I found this in my own thread. Cases that have a weep hole require an inner seal and sealed bearing. Otherwise not. Picture courtesy of SaFis.
px 125 disc
px 125 disc
Thanks for that, something to (easily) check.
@roland87 avatar
@roland87 avatar
And if your have worn internal seal and want just go to external you also need to block that little weep hole.
@orwell84 avatar
@orwell84 avatar
More good info! There is always a way.
px 125 disc
px 125 disc
I have done a search for the external seal 31*47*7 seal and found loads, am I looking for a particular specification?
@roland87 avatar
@roland87 avatar
I prefer to use simple blue Corteco without any extra specs.
But on the other side there is seals what have spin direction.
Here is seal for driveshaft Vespa ET4/LX/S. And you can see marking arrow for spin direction. Also there is notches on the inner lip.
[ Time: 0.0107s ][ Queries: 4 (0.0041s) ][ live ][ 313 ][ ThingOne ]
