@oxymoron avatar
@oxymoron avatar
Just picked up a new LX for the wife and it's having starting issues. It will crank but not turn over. A jumpstart will give it the extra push, so will removing and charging the battery. This all points to the battery, but when I throw it on a tender, it goes from red to green in less than an hour, implying that it's not a dead battery issue.
I'm running a YTS12-BS, but haven't checked it with a multimeter yet.
Any ideas? Fuses maybe, starter?
@jkj-fz6 avatar
@jkj-fz6 avatar
It's the battery. The battery tender will not tell you how much capacity the battery has left. You need to test it under load, either with a battery tester at a store, or with your multimeter as the starter is trying to start the scooter.
No idea on the age of the battery, I suppose? A weak battery may not have enough oomph to start, despite looking charged on the tender.
In my world, cranking is synonymous with turning over. Did you mean firing?
Definitely the battery.
And please don't say "it cranks but won't turn over" - the term 'turns over' means the starter will turn the engine over.
You meant "it turns over but won't start".
[ Time: 0.0076s ][ Queries: 3 (0.0016s) ][ live ][ 313 ][ ThingOne ]
