@mopedlar avatar
2001 GTS Super (white), 2021 GTS Super (yellow), 1976 Bianchi Snark moped, 1980 General 5 Star moped
@mopedlar avatar
As my 2021 GTS 300 Super HPE slows down, I'm hearing a chirping noise when the speed gets below about 10-15 mph. My brakes are not being applied when it's chirping. When you get over 10-15 mph or when you come to a complete stop, the chirping noise stops. I can't definitively tell if it's coming from front or rear, but I think it's from the front. Just started doing this today. Bike has less than 2k miles on it. Any ideas?
0:7 And counting
0:7 And counting
I know you said you're not applying the brakes, but... generally, that sound comes from the brakes.
From the wiki: FAQ: Why do my front brakes make a whirring / cricket sound?
0:7 And counting
0:7 And counting
Also, sound is notoriously difficult to diagnose via text descriptions. Any chance of capturing a video of it and uploading to YouTube?
@mopedlar avatar
@mopedlar avatar
It's definitely not the brakes. I'm not even touching the brakes when it starts chirping.
0:7 And counting
0:7 And counting
Can you elaborate on chirping? It's hard to diagnose sound from text descriptions.
@mopedlar avatar
@mopedlar avatar
Since it only chirps when the bike is moving, there no way I can get it on video without killing myself. No noise on the stand when at idle or when I accelerate from idle.
@mopedlar avatar
@mopedlar avatar
It literally sounds like a bunch of birds chirping. No other way to describe it.
0:7 And counting
0:7 And counting
I still think it's coming from the brakes, regardless of whether you are applying them. The calipers brake pads are still basically touching the disc even without being applied, and they're the one thing that is most likely to make noise.
⚠️ Last edited by jess on UTC; edited 1 time
@mopedlar avatar
@mopedlar avatar
jess wrote:
I still think it's coming from the brakes, regardless of whether you are applying them. The calipers are still basically touching the disc even without being applied, and they're the one thing that is most likely to make noise.
I checked movement of the front wheel on the stand. No binding or chirping noise whatsoever as I rotate the wheel. That's why I didn't think it was the brakes.
0:7 And counting
0:7 And counting
They don't need to bind to make noise. The pads are literally touching the disc at all times.
@mopedlar avatar
@mopedlar avatar
My wife has the identical bike and no chirping on slow down.
@bluside avatar
2020 GTS 300, 2011 LX150ie
@bluside avatar
I agree with this. My 2020 GTS mades a chirping sound when I move it around with the engine off. I'm sure it's my brake pads rubbing on the disk. I figure it's just one of those things.
OP- Does the sound stop when you lightly apply the brakes?
@mopedlar avatar
@mopedlar avatar
The chirping noise does not stop when the brakes are applied.
0:7 And counting
0:7 And counting
Okay, here are your three options, in descending order of likelihood:
1) It's the brakes. I realize you are convinced it is not the brakes, but it is the most likely candidate.
2) It's the wheel bearings. No idea why it would only chirp at specific speeds.
3) You have an actual bird nest under the fender.
My money is on the brakes. That's my final answer. If you don't like the answer, sorry.
¯\_(ツ)_/¯
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
10-15mph is typically the speed at which the clutch disengages. Above that speed the clutch is engaged, fixed, therefore no slip, and below the clutch runs free, also no slip. At the disengagement point there is slip and that slip could explain the noise.
Do you hear shortly a similar noise when you start from standstill?
If it is then it sounds like when there is slip in the clutch you have that noise.
@mopedlar avatar
@mopedlar avatar
I don't hear the noise when I move from a standstill. Only on deceleration.
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
You can record a video to capture audio without having three arms.
a. put the phone in a breast pocket
b. put the phone in a small fabric bag and hang it from the curry-hook
c. put the phone in a fanny-pack or similar
As long as the mic is free from obstruction, those with the Golden Ear may be able to give you a more educated guess.
vespa gts
vespa gts
İ got the same bird its the brakes
@shebalba avatar
@shebalba avatar
Is is more of a fluttering tweet/chirp accompanied by a bit of a whirr, or is it more of a screech?
@mopedlar avatar
@mopedlar avatar
Screech
@greasy125 avatar
@greasy125 avatar
I'm guessing brakes.
probably picked up some debris that's caught in the pads and it's rubbing on the rotor. or, just the slightest difference in manufacturing tolerances.
or, something is rubbing on the tire. the rear inner fender is always popular for that.
or, you actually have a nest of pterodactyls up under the bodywork. which would be pretty rad, honestly.
@mopedlar avatar
@mopedlar avatar
I guess the consensus is the brakes are the culprit. That's fine. I'll just keep an eye and ear on it and see if it gets any better or worse. Thanks everyone for your input. Much appreciated!
@phaskins avatar
2006 250ie
@phaskins avatar
2006 250ie
I'll throw one more idea out there, though the age and mileage on your scoot don't support the hypothesis. I had what I would have described as a non-brake, chirping noise on deceleration down from 20ish to 10ish. It turned out to be the coolant pump bearing. No real sign the bearing was going other than the sound and a bit of coolant at the weep hole. Check your pump housing.
@mopedlar avatar
@mopedlar avatar
I took her out again, still making the chirping noise on deceleration starting at about 15 mph. Checked the water pump housing. No leaks anywhere. I'm just gonna have to live with it unless it gets any worse. Thanks for your reply!
2007gts250ie
2007gts250ie
without hearing the chirp for myself I would likely apply some break clean to the to brakes, while wheels are turned. If break clean failed to remove chirping the would likely do the same as you are thinking wait for noise to get worse to enable identifying what the cause is. Good luck, may your concern be alleviated soonest.
@miguel avatar
@miguel avatar
I had a sound like this that plagued me on my 2009 GTV250. It ultimately went away when I replaced my variator at about 14K miles. Just another thing to consider.
Miguel
i put frando brakes on a few months ago and they make a very annoying jingly sound when braking. one of the reasons I regret buying these brakes.
@shebalba avatar
@shebalba avatar
Helpful info. These were on my upgrade wishlist. I assume it's not limited to just the front or rear?
@yellow300gts avatar
300 GTS supertech HPE
i have changed both bearings at my rear wheel, and i am about to do it again...maby it is that kind of chirping??
frando rear was perfect but not worth the money as stock oem rear easily locks the rear wheel. I only did the rear to match the front style.
some people here have been happy with the frando front but I never got them firm. I took it to mechanic who power bled it and also activated the abs but no luck. did all the tricks I could find like holding the caliper high when bleeding and also trying strapping the brake lever over night. nope, never been happy. And the jingle sound when braking - aarrggh - so annoying.
@shebalba avatar
@shebalba avatar
If the rear brake was perfect and other owners have been happy with theirs, did you explore the possibility of a defective front brake?
I'm in Australia and I bought them from Germany. Installed myself. Having the argument about refund/replacement sounded like too much effort. Whereas if it was down the street at the local dealer and they had installed them ...
The rear are a size and design that is very similar to original so not surprised that they just worked. Front are so much bigger and have the weirdness of the line in and bleeder being right next to each other which really makes me suspicious of the layout of the channels inside the calliper being no the best thought out, and with the considerable more total piston area being pushed by the same size master cylinder ...
[ Time: 0.0113s ][ Queries: 3 (0.0044s) ][ live ][ 313 ][ ThingOne ]
