I recently replaced the fork seals on my fly 150 and after reassembling the front end now I'm having an issue with my brakes, I tried the brake fluid change procedure from Mitch's repair videos, did exactly what he did, for HOURS but no brake pressure, fluid dribbles out the brake drain valve a drop or two at a time or not at all, it's new fluid too at this point with some air bubbles also but no pressure in the brake grip?
I also noticed there's a small hole in this rubber piece on the master cylinder where the grip contacts it and pushes it in,
Could this hole in that rubber piece be the cause the brakes not having pressure or could it be something else?
Maybe disassembling the master cylinder damaged it in some way? It is a little bit corroded and had a stripped screw that needed some work to get out.
My brakes worked fine before I replaced the forks, it probably is the original master cylinder and who knows how long since the fluid had been replaced, not in the 2+ years since I've had it. I did pressure test the cylinder with the brake line off and it did create a bit of suction when my finger was placed over it, also tried clearing/pressure testing the line with an air compressor, it seemed ok, no noticeable air leaks or other wet spots anywhere that I could see.
I'm not sure what to do here, considering replacing the master cylinder but thought id run it by you guys before throwing parts at it.
