Vespa GTS125 Super IE 2012
Hi - first timer here but, having searched I couldn't find anything on the following.
I bought a Vespa recently and am looking to change the oil. Currently fitted is an HF197 filter, however everything I read online points me towards an HF183.
What's the difference? I assume diameters - but which one do I need? The manual simply points me towards a 'C' rather than specify filter.
Any ideas?
Thanks in advance!
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
An older thread says the HF 197 has a hex on the end and the HF 183 doesn't.
@dooglas avatar
@dooglas avatar
Nightwing is correct. The two HF filters are identical in size and capacity. The HF183 has a slot on the top allowing it to be removed with a metal rod or the side of a screwdriver, while the HF197 has a hex head allowing it to be removed with a hex drive. I far prefer the hex head for ease of removal.
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
Get the HF197, you will find it easier to take off.
[ Time: 0.0109s ][ Queries: 3 (0.0039s) ][ live ][ 313 ][ ThingOne ]
