ET4 125cc 2002
ET4 125cc 2002
Hi All,
Just registered as need some help. Vespa ET4 125cc 2002 model and have stripped carbs down and cleaned, main jet, idle jet, holes under diaphram.. it will start for about 20 seconds and then cut out. The vacuum line doesn't appear to open the valve tank valve while connected to the carb. If you remove and suck it does start and maintain running, is this a carb issue with not creating a vacuum or is it the extra negative pressure on the tank valve when sucking the hose.
Appreciate any help.
@slowpoke avatar
1952 allstate (early), 1958 allstate, 2009 S150, 2001 ET2
@slowpoke avatar
Can you post a pic of where you have the lines on your carb hooked up? It most likely is the fuel tap that needs to be replaced.
ET4 125cc 2002
ET4 125cc 2002
Hi Slowpoke,
Not sure why I'm struggling to post a pic, sorted… fuel line is top of the vacuum tap and goes to rhs of carb at high level, vacuum line come from lower lhs of carb and you have a drain line from carb bowl that drops to bottom of bike.
@slowpoke avatar
@slowpoke avatar
What's with the fuel filter that is installed on the EVAP line? There is no fuel filter installed on these bikes since there is a screen on the fuel petcock. The fact the fuel filter looks to be on a vacuum line might be causing a drop in pressure.
Also I would cut that zip tie and on twist the lines up at the gas tank.
@slowpoke avatar
@slowpoke avatar
LX150 Complete EVAP System Removal
Here is an EVAP removal article, for reference you can use this to make sure yours is hooked up correctly.
ET4 125cc 2002
ET4 125cc 2002
Hi Slowpoke,
I've checked and I don't believe my ET4 has an evap system, on the petcock what nipple is the vacuum line and what is the fuel line. Top or bottom?
'07 GTS250, '07 LX150, '81 P200E, '78 P200E, '64 V90 and 3 Ciaos
Is it me, or do the fuel and vacuum lines look reversed? Vacuum should be on the bottom of the tap, so it can pull down the tap diaphragm and allow fuel to flow.
Where does the "T" branch of the black/green hose go? I believe that should be on a carburetor vent pipe if you don't have an evaporative emissions system.
ET4 125cc 2002
ET4 125cc 2002
Vacuum line is connected to the lower nipple on the petcock, but the carb is either not creating a vacuum or the petcock is not pulling down because due to it being faulty.. if you suck the vacuum line the bike will run. Think I will change the petcock and remove the bin line fuel filter.
The T section goes to the inlet manifold after the carb.
@slowpoke avatar
@slowpoke avatar
The in line filter will slow speed of fuel on these gravity feed scooters. The fuel petcock is most likely your problem here.
Let us know if that fixes it.
Where is the gray line from the fuel tap vacuum port connected? It looks like it's on the fuel inlet for the carb.
I suspect the terminating locations of the green and grey sleeved hoses might be reversed. You shouldn't be fuelling your engine through the vacuum port on the intake manifold.
ET4 125cc 2002
ET4 125cc 2002
The carb has 3 hoses
1. Fuel line comes off T section and connects high on the rhs of carb below diaphragm cover.
2. Vent line connects to the carb below choke connection on lhs
3. Drain line from bowl on bottom
[ Time: 0.0156s ][ Queries: 5 (0.0078s) ][ live ][ 313 ][ ThingOne ]
