@suse avatar
2013 Vespa 946 & 2023 BV400
@suse avatar
Hello, went thru the older post for BV350 brake levers, and basically same situation/question here, but for a 2023 BV 400--having less reach to the lever would be wonderful, so hoping for any ideas for replacement levers... Not sure if the same are compatible with the new BV400? (why do I suspect very little is compatible between the different models?? ) I already asked Scooter West, and they had no knowledge of any or any leads...
I have gotten used to dealing with the long reach with nearly a year with my 946--but the BV400 feels like an even greater reach. In fact a couple blocks after I left my dealer, I turned around to go ask them if they knew of an adjustment... Any ideas appreciated!
@bobo avatar
@bobo avatar
There are these on AliExpress. I assume they would fit.
@suse avatar
@suse avatar
Thank you Bobo, I will check those out!
another thought:
lookup the part number for the levers on your bike and then search the part number to see what other bikes use the same lever.
[ Time: 0.0081s ][ Queries: 4 (0.0020s) ][ live ][ 313 ][ ThingOne ]
