@vetteb_96 avatar
2022- 300 GTS SuperTech
@vetteb_96 avatar
I have a blemish in my matte paint from a tie down strap while I was transporting it to Florida. Seems I'm stuck with it. It's in an odd spot but I was thinking of covering it up with a sticker? What should I do? Live with it or try to cover it up. If i had normal paint I would sand and buff it out. Sucks!
You might know it's there - others won't notice it. Nor will you in a few weeks.
A sticker will remind you of it all the time.
I'd just accept it, and treat it as having lost its virginity. Inevitable later scrapes will feel far less important.
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
What about a really light sanding with some 5000 grit sand paper?
@robalatte avatar
GTS 300's
@robalatte avatar
GTS 300's
Totally a bummer. You might try the Matte Paint Cleaner that scooter west has, on my old 22 silver matte super tech, it worked well to take out a minor scuff.
Matte paint is very very unforgiving though. Like others said, it might burn a bit today but the burn will subside and hopefully it won't bother you moving forward.
@bob_copeland avatar
vetteb_96,
I know many want their Vespa pristine in every way. I was also
among this group of anal retentives. After getting a small scratch
on my brand new Kymco 550, I have been slightly freed of this
phobia. A little factory touch of paint did the job.
As posted above, most will never notice it. This will not help
if you are in the above anal category. I say set your self free,
yes, free at last, free at last.
Martin Luther King
I have a Dream, Thank God Almighty we are free at last.
@jonniedee avatar
2023 GTS 300
@jonniedee avatar
2023 GTS 300
I fixed a tank bib scratch on a HD matte black tank with a light 1200 grit wet sanding. Whatever you do no rubbing compound!
@mitleider avatar
2024 GTV & 2024 GTS Supertech
@mitleider avatar
That's painful, I can sympathize. If it were mine, I'd have professional repair it. The matte finish is provided by a special clear coat over the color base. It may well be simple to have the area sanded by a professional and clear coated. Good luck
[ Time: 0.0158s ][ Queries: 4 (0.0081s) ][ live ][ 313 ][ ThingOne ]
