Hi guys!
I have a Vespa GTS 300 Super 2017.
At first start it starts properly. Later i stop and try to go again but it wont start.
Sometimes its turns over but doesnt start. After a couple of tries maybe its starts but sometimes I still have to play with it. If I pull the throttle and let it go, it starts. But just when the throttle went back to the normal position not before.
When I stop at a light its starts to decrease the rpm and almost stops. Several times it does. Sometimes the ASR lamp comes on as well.
What should be the problem? Electrical or mechanical?
Thank you
@der_blechfahrer avatar
Could be a faulty fuel pump. Try riding with a half tank and stop at a gas station when you think the problem will appear. If it does, see if filling up with cold gas can solve the problem. Alternatively, see whether waiting 30 minutes will make it go away.
Could be the air idle bypass in the throttle body is partially blocked. This means the mixture will be too rich at idle when the engine is fully warmed up, causing lower rpms and occasional stalling.
Opening the throttle and closing it again would allow some fresh air into the intake manifold, which would alleviate the 'too rich' scenario.
Solution - clean the air idle bypass:
https://cheekythoma3.wixsite.com/itsme/idle
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
Valve adjustment???
my first thought is the same as jimc
'06 GTS 250; '18 GTS 300; '21 Liberty 150
I had a very similar problem, '18GTS. Replacing the OEM starter fixed the issue. After trying the relay and battery, neither were the problem.
Bike would start cold every time. Once warm it would be random if it would crank over or give me nothing.
Update!
A new mechanic has determined that the ECU is faulty. During driving, there are instances when the RPM drops slightly, as if a stronger gust of wind is hitting, but it's not related to the weather. I'm about to purchase the new ECU, I'm ordering it from SIP. Does it come with a master key, or can the old one be programmed for the new ECU? Customer support is quite slow to respond to anything.
Vespa GTS 300
Vespa GTS 300
imbensmith wrote:
Update!
On new/virgin ECU first(!) Key used/programmed is automatically new Master: Make sure that the brown one (with foldable Chip) is used first. A foldable Chip makes programming secondary keys much more easy.
Immobiliser Codes:
Immobilizer LED codes
How to programm Keys:
ALL: Programming New Keys
Thank you.
The seller didnt find the brown key. So I have the new ECU but dont have brown/red key. Do you know where can I order new ones with the lock as well?
Cheers
imbensmith wrote:
Thank you.
Cheers
https://www.sip-scootershop.com/en/product/cylinder-locks-ignition-lock_MV577454
@preddybaer avatar
GTS300, CRF1000 & Moto 6.5
@preddybaer avatar
I had similar problems with my Froggy (after comming back from a regular maintenance, other story for other time).
After long root cause investigation and changing various parts, it came out to be the code antenna (example here at SIP https://www.sip-scootershop.com/en/product/antenna-piaggio-immobilizer_PI638534?q=code%20antenna). Once it was swapped, never had the same problems again.
Very expensive part for a piece of plastic with a connector and the copper coil (and a printed P/N sticker)!
If you manage to get from someone spare part to try it, do a check. It helped Froggy. By the way, Froggy way MY2017 GTS 300 in gorgeous metallic green.
@preddybaer avatar
@preddybaer avatar
imbensmith wrote:
Thank you.
Cheers
you better find that brown key or it will become quite expensive. that is your MASTER key.
If the seller did not sold you Vespa with the red key, get back to him/her. That is your only chance. Otherwise you'll need to change a lot of components which are connected with the immobilisation system.
Cheers man. Is that a master key? So It will behave like a brown/red key with the new ECU?
Because I already have the new ECU.
Did you change the ECU as well? Because I just have the new one. Maybe it will be solving my problem. But yeah, new master key neccessary cause the guy still didnt find the master key
@preddybaer avatar
@preddybaer avatar
since I had my red master key, replacement of the ECU was not necessary, only the blo*dy antenna part I gave the link for.
in your case I presume that, with the missing master key, you do not have any other option than to change ECU as well. but only swap of the antenna will most likely sort out the problem described in the introduction of the thread.
sorry mate for bringing the bad news. my problems occurred in the guarantee period after being at regular maintenance. let's say that I did not managed to get it corrected under Guarantee and that the event spoiled my relationship with the Service I was liking to go to (in addition few other minor things which came along and confirmed that my decision was correct, at least in my case). I have now new Service I am more than happy about.
[ Time: 0.1109s ][ Queries: 5 (0.0997s) ][ live ][ 313 ][ ThingOne ]
