@rob98801 avatar
85 Vepsa PX150E with sidecar, 80 P200 with sidecar, 96 Goldwing with Hannigan Sidecar, LR87aj5, LR91aj3
@rob98801 avatar
The video shows AC output across the two yellows coming from the engine case. The engine is set to a fast idle.
Note the changing voltage. If engine is set to a higher RPM the voltage will drop to 5VAC to 7VAC.
The voltage across the two yellows without load attached follows RPM up to 35 or 37VAC.
This all came about after battery wasn't being charged, Two new regulators and still not charging.
Flywheel Magnets? OR?
2009 mp3
2009 mp3
Digital meters will do that. Depends on which part of the wave it reads at the time. An analogue meter is much better for reading that sort of thing.
@markosmarkos avatar
You state you have two yellow wires. This points to the older, not-manufactured-anymore, 4 pin regulator (double-yellow) system. However, in 1980, most were swapped over to the 5 pin regulator (yellow-red system). It could be an incorrect regulator/rectifier you may be using that is not charging the battery. There are workaround regulator/rectifiers for the double yellow system. You may want to show a picture of which regulator you are having issues with and verify which stator/wiring harness you have.
@rob98801 avatar
@rob98801 avatar
Out to the Garage.........Back in a bit.
Shades of red flush over my face.... EE degree ( vacuum tubes were my thing), Taught many electronics classes... but all that was 35+ years ago.
Out to the garage.. dig to the back of the cabinet..find my trusted Triplet model 630-apl muttering the whole time something about "I knew that at one time"
Anyway Analog to the rescue. All is well.
Thanks to all.
⚠️ Last edited by Rob98801 on UTC; edited 1 time
@gickspeed avatar
@gickspeed avatar
This is more like a solution looking for a problem.
The two yellows are floating on the stator. I would be more apt to check the B+ post on the rectifier. This would be your DC output to the fuse. Are we sure we have the correct rectifier because that thing is very specific.
https://www.scooterhelp.com/electrics/wiring/VSX1T.USA.before.pdf
[ Time: 0.0086s ][ Queries: 3 (0.0016s) ][ live ][ 313 ][ ThingOne ]
