@roberthuttinger avatar
Motovespa 150s MK2 65 502m
Greetings friends! I ha e been looking everywhere and I cannot find clutch friction corks and plates for my particular clutch (seems to be a match for VBB2) Ø115mm for the plates (not the diameter for the whole clutch, the plates themselves including teeth)
Any ideas for other search terms or sources? I have tried the shops listen and been searching for two days. I suck at searching, am searching fro the wrong thing, or they just aren't available?!
Motovespa 150s mk2 65 Clutch with plates, basket, and measurement.
@safis avatar
@safis avatar
You only measure the cork part. Diameter should be around 108 as most stock baskets..
Measuring the cork part is much closer to 108mm (106.5 really). The inside of the basket is iØ 108mm,
This explains why I couldnt find anything!
Thanks Ill try a new search!
[ Time: 0.0148s ][ Queries: 4 (0.0039s) ][ live ][ 313 ][ ThingOne ]
