Vespa GTS 300 Super Sport
Hi Guys, Electric start and Horn Weren't working on my Vespa Px so I charged the old Battery but found out it was Knackered so got a new Battery. I put in the new Battery and with no Key in the Ignition scooter turned off I touched the Clutch Lever and it Tried to Start ?? I'm very Puzzled here any ideas ? is the Starter relay needing Replaced ? ... Thanks in Advance
@jkj-fz6 avatar
@jkj-fz6 avatar
Yes, it's most likely the starter relay.
@safis avatar
@safis avatar
Probably a stuck relay, especially if it's the old type (metallic). Get the newer type (plastic) found on almost every Piaggio scooter. Direct replacement and cheaper…
Old type
Old type
New type
New type
Can't be the relay, as it only connects when power is applied to the coil - i.e. when the 'clutch' (rear brake!) lever is squeezed.
The starter button is jammed on, or otherwise shorted inside.
@safis avatar
@safis avatar
It's a PX. Brakes aren't involved with the starter circuit. There's also a small 'safety' relay behind the horn cover which gives the 'OK' when clutch is pulled in…
Ah yes, thanks for the correction. The logic still stands though, the relay isn't at fault if it only switches when power is applied to the coil (as it should).
Starter button switch faulty for sure.
Moving this thread to NSM.
Seems to me that your relay coil is getting a permanent live from somewhere. Even with the starter button stuck in, it shouldn't try to start with the key out and off, as there isn't any power to it.
Pull off the feed to the relay (normally pin 86) and see if it still does it. If it does, it seems like the relay is shorting inside.
[ Time: 0.0099s ][ Queries: 4 (0.0034s) ][ live ][ 313 ][ ThingOne ]
