Fri, 02 Jun 2023 17:35:38 +0000
Mp3 350 sport 2020
Mp3 350 sport 2020
Fri, 02 Jun 2023 17:35:38 +0000 quote
Noticed today that the left wheel( right in the picture) has a small angle facing outwards.
Also when I go in a straight line and let go of the handlebars, the scooter wants to lean right and can't keep a straight line.
Is the wheel angle adjustable?
Fri, 02 Jun 2023 20:03:15 +0000
2016 Mp3 500ie Sport
Fri, 02 Jun 2023 20:03:15 +0000 quote
Previous threads on similar topics
MP3 500 Handlebars and Front Wheel Alignment and Fork play: is it dangerous?
JIMC mentions a "Pinch Bolt" in the replies. If you can locate this in the parts diagram then you can sort out how to access it.
This is the MP3 500 2018 series parts diagram for the front suspension.
https://www.parts-piaggio.com/piaggio-scooters/500-PIAGGIO-SCOOTER/MP3/2018/MP3-500-Sport-E4/Suspensions--Wheels/Forks-components-Mingxing-/1214/20/15772/2701
Sat, 03 Jun 2023 06:01:03 +0000
2015 MP3 500 ie Business
Sat, 03 Jun 2023 06:01:03 +0000 quote
The suspension usually does not go out spec unless the vehicle sustained a frontal impact or rough roads (especially potholes) which usually leads to bent suspension legs.
It is the bent legs which is usually the primary cause for the alignment (wheel angle) being off.
Sat, 03 Jun 2023 09:36:36 +0000
Sat, 03 Jun 2023 09:36:36 +0000 quote
Are we talking about a vertical axis problem (toe-in or toe-out) or a horizontal axis problem (camber)? A toe problem is just the rather flimsy steering bar that's bent, rather than a bent leg (camber).
Sat, 03 Jun 2023 22:43:31 +0000
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Sat, 03 Jun 2023 22:43:31 +0000 quote
First set the bike level Set it on the stand and disengaged the lock
Then messure the front and the rear of the front tyres the only thing you can adjust are towin or out
If you got camber on one wheel then something is bend
⬆️    About 10w elapsed between posts    ⬇️
Thu, 10 Aug 2023 23:25:02 +0000
mp3 500
mp3 500
Thu, 10 Aug 2023 23:25:02 +0000 quote
Remember looking straight at the front of your bike the wheels will appear to toe out do to perspective. ( don't beleive me? look at rthe front of your car)
Sat, 12 Aug 2023 16:01:51 +0000
Sat, 12 Aug 2023 16:01:51 +0000 quote
Check out this thread on moving a washer to correct alignment. At a gathering a long time ago we demonstrated the fix.
Sat, 12 Aug 2023 16:02:17 +0000
Sat, 12 Aug 2023 16:02:17 +0000 quote
Correcting Front Wheel Alignment
Thu, 17 Aug 2023 00:20:33 +0000
Thu, 17 Aug 2023 00:20:33 +0000 quote
Finally made it to Kentucky to check out rides. Most importantly verified the acceptable availability of nourishment to keep us going.
Sun, 20 Aug 2023 21:08:16 +0000
Sun, 20 Aug 2023 21:08:16 +0000 quote
hmm ice cream to fix a front end alignment issue. sounds bout right.
  DoubleGood Design
[ Time: 0.0303s ][ Queries: 6 (0.0077s) ][ Debug on ][ 286 ][ Thing Two ]
