@greasy125 avatar
@greasy125 avatar
breaking these two crashed bikes, both are carb'd. LXS is red, LX is midnight blue.
what plastics are left are kinda so-so but might have some use for somebody that just needs something that will work and isn't perfect.
lots of mechanical parts! all the fiddly little hardware. speedo clusters, headlights tail lights, shocks, carbs, throttle/brake cables and what not. one complete motor. rims, rims, and more rims.
NO FORKS! both bent, but have all the other parts.
red LXS has a pink and clear title, could be saved if somebody was so inclined.
PM with your laundry list, the more you buy the cheaper it gets!
I'll get some pics up over the next few days.
⚠️ Last edited by greasy125 on UTC; edited 1 time
@greasy125 avatar
@greasy125 avatar
few pics:
headlight has a very small hairline crack at the top, barely noticeable. both the front cover and rear cover have broken tabs and scratches. come as you see them, complete with all the switches, hardware. one mirror has some deep scratches, the other just a few dimples.
fold down rack is OEM vespa with the integral grab bar. the other grab bar is just an OEM one. head light has a little scuff but not broken, no head light ring. handlebar covers have all the tabs and mounts, but are scratched up. no cracks. those are all the floor strips jumbled up there. everything is is pretty self explanatory.
speedo cables for LX an LXS, rear brake cables, both bikes were dual throttle cable. the calipers and master cylinders look a sight, but it's just the paint coming off the surface, nothing was leaking before blowing it all apart. shocks felt good, rotors have a lot of meat left on them.
@greasy125 avatar
@greasy125 avatar
more pics:
the glove box is missing a little bit of the edge on the right side about midway, the leg shield beading hides most of it. other than that it's quite decent and the glove door works and hook mount isn't busted. the footboard is a little chewed up on the upper right where it meets the body, but other than being dirty and scratched is otherwise a functional piece. the foot pegs are all scratched. the rh fairing has some pretty deep gouges at the top edge (it's the one w/ the reflector but nothing cracked or broken. the lh fairing has some scuffs but looks like it will buff out. the other pieces have various scuffs and scrapes, the inspection cover is clean though.
both of these are rough, but if you need one they're cheap! the black is just the paint coming off. I do have the bins and all the rubber strips. there is a short crack at the top left in the crook of the neck. easily plastic welded or zip tied. the foot board has a crack there on the left you can see in the pic. easily fixed or run as is. the edges have a fair bit of rash as do the foot pegs.
pair of fuel pumps, some misc lights and plastics.
++both wiring harnesses are complete, uncut and come with CDI & key/lock++
these are as removed and have ALL of the clips, grommets, relays and mounting plates.
if you're thinking about swapping a 150 into your 50, this is the piece you need!
I also have tanks, pet carriers, and all the evap crap. if you don't see what you're looking for, ask. I probably have it!
@greasy125 avatar
@greasy125 avatar
figured I'd just add this here as well....
LX front & rear handlebar covers. originally red, these were professionally painted black and look great. there are no broken tabs, no stripped screw sockets, chips or cracks. the head light has a decent scuff but is otherwise fine. comes as you see it with the switches and signal pods.
⬆️    About 28 days elapsed    ⬇️
@greasy125 avatar
@greasy125 avatar
ALL blue LX body parts are sold!
LX tail light, mirrors, signals & marker lights are sold!
LX speedo cable sold!
1 rear brake cable and rear brake perch/level sold (have 1 brake cable left)
tons of parts still available at little birdie prices (cheep-cheep), if you don't see it ask!
@greasy125 avatar
@greasy125 avatar
last call on these LX/LXS bits. some great parts left, dirt cheap prices, fast shipping. if you don't see it, ask. I probably have it!
[ Time: 0.0110s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
