If you want to install the the Faco flyscreen on your Liberty and are using the Robot video to install reverse the mounts from the way Robot shows and you will be able to install the nylock nuts and cap on the bottom screen mount otherwise the screws can hit the headlight trim. I also installed the side stand kit and really like the convenience.
