Looking at getting either a Vespa Primavera or Piaggio Liberty. Looking for opinions from those with experience with those two scooters.
OFG
Hurricane 200X, 2020 TW 200 (sold), 2022 Liberty 150
Posts: 312 Location: North Alabama |
OFG |
GTS 300ABS, Buddy Kick 125
Posts: 13560 Location: Oregon City, OR |
Oldfatguy wrote: Looking at getting either a Vespa Primavera or Piaggio Liberty. Looking for opinions from those with experience with those two scooters. |
The Liberty has large tires which ride more like a motorcycle. It has a shorter range with the smaller gas tank. The handlebars are a bit lower. It is considerable cheaper (price). It has the nice flat floorboard. It's easier to work on. If you damage the side, you replace the plastic and don't need a lot of body work.
The Primavera is smoother ride but has smaller wheels. Riding my country roads and RR crossings, the Primavera doesn't jar me near as much. The seat is more comfortable. The handlebars are not as low and has a seating position more like the GTS. The tires are wider than the Liberty. More accessories available. The oil/hub is same access on both but the valve adjust is just a bit easier due to the wider panel on the Liberty, but dropping the rear shock makes both an easy job. The Liberty requires removal of panels starting at the back to fully remove the front, but you can do some wiring/accessories by wedging your hand between the panels without fully removing for most mods. Shorter front fender on the Liberty can (depending on your roads) make the area behind the front tire very dirty, but it is simple to clean. I cleaned it daily. The Primavera can put on a short fender extenda and avoid most of that dirt thrown on the panel. The Primavera footrest for the passenger is very different than the Liberty. If you plan to carry a pillion, make sure they test sit on it or you could suffer some back pain after a short ride. I found that I miss the flat floorboard the most. But had I not had the Liberty, it wouldn't have been such a big item on my list of missed items on the Primavera. If you want a windscreen, you have a small choice with the Liberty, BUT you can use GTS windscreen though the cutout for the headlight is round instead of that triangular shape. Function vs looks. Another thing about the windscreens. The Primavera windscreens work as expected. The Liberty needs some black moulding or other way to block the headlight beam from glaring on you IF you ride at night. You can search the forum for solutions and examples. Last thing I can think of at the moment is the angle of the ignition switch. On the Liberty it is easy to just insert the key and go. On the Primavera, it is at a slight downward angle that seems to throw me off even though I know it is like this. I've never heard anyone else mention this, so it may just be me. Ooops, one more last thing. On the Liberty, you can remove the fuel insert to make the fuel filler hole large and not spew the fuel. On the Primavera, it is molded into the tank and can't be altered. 99.9 don't, but just in case you would.
Highly Rated
Posts: 2536 Location: Sydney, Australia |
I chatted with the guy that made that video and after that, he convinced me to get the Liberty. I don't regret it. AS Robot said, it's the best bang for the buck.
I would have preferred the Medley too when I was making the decision. But not available in the states. |
Posts: 2754 Location: Ohio |
Well clampett seems to be your guy - he has both!
I love my Liberty ~!- had it new since we unboxed it at the dealers, summer of 2017. However - if you're only going to buy one - you probably will face buyer's remorse that you didn't go with a genuine VESPA! I'll let it go at that - esp considering the neighbors.... O.S. |
2020 Piaggio Liberty S 150, 2016 Vespa GTV300ie, 2009 Yamaha C3
Posts: 163 Location: USA |
I have a Liberty 150 and a Vespa 300, so while I can't compare it with a Primavera per se, the ride feel of the bigger-wheeled Liberty vs the Vespa is quite different, personally I really prefer it. The flat, large floorboard makes it easy to carry items, as well as to adjust your seating/feet position quite a bit as needed. The only thing that annoys me to no end is the fuel tank-- it's a small tank (so I'm filling up more often), and it's a tricky tank to get full. However, every other thing about the bike is awesome, so it's a worthwhile trade IMO. It's a super fun and reliable little workhorse.
As for the price point, I bought mine new from a dealer and it was about $4000 out the door, with taxes/tags/etc. My S.O. just bought the Justin Bieber 150, same engine as the Liberty, and his OTD price was closer to $9k. Personally, if (heaven forbid) I could only own one scooter, the Liberty would win every time. |
The Bieber is just white Primavera with stickers. My dealer is taking those stickers off and reducing price to sell them.
Too funny
Clampett wrote: The Bieber is just white Primavera with stickers. My dealer is taking those stickers off and reducing price to sell them. |
Outsider wrote: All I have to say is it is not a Vespa. |
Posts: 262 Location: SF Bay Area, East Bay, California |
Having owned a Sprint 150 and a Liberty 150 within a few weeks of each other, I'd like to echo everything that Clampett said above. One thing I would highlight a bit more is that the ergos many be different enough to warrant spending a little time on them and thinking about how you ride. I have long feet and long legs, so while I initially thought the Liberty was going to be fine, the lack of a sloping frame to let my feet stretch and the slightly more compact ergos of the Liberty (ex. can't easily turn lock due to knees in the way) have finally driven a wedge between us and I'll probably sell it soon. Moreover, there seems to be a lot more easy aftermarket options—I got a used Corbin seat for the Sprint which really changed the ergos to downright spacious.
⚠️ Last edited by besupa on UTC; edited 1 time
besupa wrote: <snip> Moreover, there seems to be a lot more easy aftermarket options—I got a used Corbin seat for the Sprint which really changed the ergos to downright spacious. |
besupa wrote: Having owned a Sprint 150 and a Liberty 150 within a few weeks of each other, I'd like to echo everything that Clampett said above. One thing I would highlight a bit more is that the ergos many be different enough to warrant spending a little time on them and thinking about how you ride. I have long feet and long legs, so while I initially thought the Liberty was going to be fine, the lack of a sloping frame to let my feet stretch and the slightly more compact ergos of the Liberty (ex. can't easily turn lock due to knees in the way) have finally driven a wedge between us and I'll probably sell it soon. Moreover, there seems to be a lot more easy aftermarket options—I got a used Corbin seat for the Sprint which really changed the ergos to downright spacious. O.S.
Positive
Clampett wrote: The Bieber is just white Primavera with stickers. My dealer is taking those stickers off and reducing price to sell them. I told him a Liberty would have been much easier to maintain, as he loves mine and it was his close-place second choice. |
Bobo wrote: Depends on how you look at it. For me personally, a real Vespa is a 2 stroke manual shift. Not that I don't like modern Vespas. It's just that growing up it's what a Vespa has always been for me. To paraphrase Magritte, c'est ne pas une Vespa. |
We'll obviously if it comes out of the Vespa factory and it has a Vespa badge on it, it's a Vespa. What I meant was when I imagine a Vespa, I imagine an old shifty. And it's not a Vespa MP3. It's a Piaggio.
