HI guys! Already read all the posts about the ac balanced circuit and still got a problem. I bought the treatland AC regulator and connected one to the yellow and one to the blue at the junction box. i am still getting taillight bulb to blow up, everything else is working fine. what should i check? thanks !
LED's are hit or miss on AC systems.
If you have regular bulbs pop them in and see if your tail light works then or not. You'll at least be able to cross the lamps as the issue at least.
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
