Et2 50
Et2 50
Just over revs on full revs all the time
@mjrally avatar
@mjrally avatar
Air leak. Check cylinder base gasket, head torque, exhaust clamp, intake manifold for cracks, o rings, reed block and carb clamp.
Et2 50
Et2 50
Thanks I'll try that I've not tourge the nuts so might be that
If, for some reason, you put a new cylinder on hand tight and let the bike rev, you should check to make sure that you didn't break a ring or two before you button it up.
[ Time: 0.0082s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
