GTS 300ie Super
GTS 300ie Super
What's involved in replacing voltage regulator in Vespa GTS 300ie Super 2010? I've removed the glove box & front horn cover. Thanks, Neal
lift up the right side of the floorboard.
GTS 300ie Super
GTS 300ie Super
The Voltage regulator is above the R radiator on my GTS 300ie?
It's in there somewhere.
from the workshop manual. those 4 vertical metal fins that can be seen are part of the regulator
regulator above right hand radiator
GTS 300ie Super
GTS 300ie Super
My question is how do you get at it to remove it with all the coolant hoses surrounding it?
It's been a while, but if memory serves, you either loosen the reservoir or the radiator or both. It's still hard to do and requires extra joints in your fingers.
GTS 300ie Super
GTS 300ie Super
OK thanks, This is what I thought but just wanted some ones conformation before I started!
[ Time: 0.0090s ][ Queries: 4 (0.0027s) ][ live ][ 343 ][ ThingOne ]
