Hello,
Please refer to this diagram for my question:
https://www.scooterhelp.com/electrics/pages/VB1T.150.html
There is a yellow wire coming from bottom left coil and then connects to the green wire (from bottom right coil) at the distributor. From here, we have two yellows wires running to the front and to the rectifier.
The question is what is the purpose of this yellow wire (coming from the bottom left coil) and what voltage should it have when the engine runs?
When the engine runs, I measure AC voltage of the green and yellow wires individually and the result is 6V from the green one and only 200mV from the yellow one. I expect to have 6V too from the yellow one since it should carry the voltage from that coil.
Please help.
