P200e
P200e
Is there a bolt on kit that is fully hydraulic that will fit my 77 P200 with the 16mm axle?
@qascooter avatar
@qascooter avatar
Not a kit that I know of, but you can buy the parts to make it happen. I spent many years procrastinating and figuring out the best way for my scene.
You can get a semi- hydraulic kit, then a brake line, and master cylinder of your choice, and put it together. SIP website is a good place to build a wish list of components...
I chose to go with a Stella fork, Motorino Diavolo Master Cylinder, and braided line. Here is a link to what I did: https://modernvespa.com/forum/post2618976#2618976
@safis avatar
@safis avatar
The only bolt on kit is the semi-hydraulic from Grimeca that has the cable operated master cylinder installed on the fork's leg. For a full hydraulic setup, read above…
Lambretta GP200, Vespa P200e, Motovespa do Brasil PX200E
You can get the Grimeca kit for the 16mm axle. I would spend extra $$ and time and make it fully hydraulic. Or as mentioned you can piece it together from parts. Ive pieced mine together.
https://scooter-speed.com/vespa-grimeca-disc-brake-kit-front-16mm-black-so-o30007000/
@safis avatar
@safis avatar
That's the semi-hydraulic kit. No need for it if he wants to go fully hydraulic. He can get all the individual parts to make a kit…
[ Time: 0.0123s ][ Queries: 3 (0.0026s) ][ live ][ 343 ][ ThingOne ]
