PX Vespa 125
PX Vespa 125
Okay l have been trying to find out if it is normal noise through the gear's as it's a clunk click on every trip it's a new PX Vespa euro 3 model just not ridden vespa before mainly lambretter !! And I can't remember if they was the same O do you have to change very quickly up and down the gear's ! To minimise the sound ! Just need a heads up on this matter please advise !! Best foot forward soulboy74 🏴󠁧󠁢󠁥󠁮󠁧󠁿
@mjrally avatar
@mjrally avatar
Is it just a clunk each time you shift? If so, that's normal.
I'd it's a noise when you're not shifting, or getting louder/changing, you want to start investigating.
@ray8 avatar
@ray8 avatar
Love those mild clunks, like when you feel the batwing click and simultaneously clunk
Practice trying to match rpm to your rear wheel speed with the throttle before shifting, to smooth out those clunks.
If you dial up rpm at idle it will clunk more, since the rear wheel/driveshaft isn't moving.
If you coast and downshift without throttle it will clunk more.
Find those rpm sweet spots on the road and you'll be kinder to your primary springs, etc.
Does your clutch drag at all, does it try to creep forward when in gear w/ clutch pulled, and you can't adjust it out? If so, that will aggregate this problem. You may have warped clutch plates or other clutch issues.
@gthebuck avatar
PX125E
@gthebuck avatar
PX125E
I had similar clunks on my 99 P125X before experiencing clutch creep & subsequent crank, woodruff key, clutch centre hub & associated seals renewal, c.1 month after buying it. I still get the odd clunk, but like Ray8 wrote, it's all about finding the sweet spot & not warping clutch plates.
PS. There's a short vid on YT suggesting compatible motorcycle clutch plates are more robust for city driving/upgraded engines.
PX Vespa 125
PX Vespa 125
Thanks you guys no worries it's my style of riding l gus need to find that sweet spot like you said all's well just not used to clunk click maybe change a bit quicker than before should help me ! Still a bit hesitant coming down the gear's riding the clutch a bit too much l think!! Best regards soulboy74 🏴󠁧󠁢󠁥󠁮󠁧󠁿 ✊
Jet Eye Master
Jet Eye Master
If it will idle at about 900rpm while in 1st gear, holding the clutch in, all is good. Any noise is the rider.
Yes, that would be disks as described here Honda CR80 clutch disk page, what have you got? . As you can see, I really like them because they are so smooth and never slip, but you would need a 7 spring clutch from a 200 or a Cosa clutch, and his 125 has a 6 spring.
I can only add that before you start out to disengage and engage the clutch a few times to loosen up the plates when the engine is cold. Everything else is just learning to rev match and getting to know the machine. As far as the clunking goes, the older BMW airheads would clunk quite a bit because of the heavy flywheels used on those machines. And every Harley every made clunks. Just part of the magic, I guess. Razz emoticon
[ Time: 0.0185s ][ Queries: 3 (0.0128s) ][ live ][ 313 ][ ThingOne ]
