Could that come from the flywheel side bearing ? It is toast, but so much material from a single bearing ? Other bearings look fine.
Shavings are magnetic, so it does not come from the casing.
The picture shows maybe 30% of all shavings I found everywhere in the engine.
I don't have much experience in engine rebuilt, but I think the crankshaft looks fine, a bit of corrosion on 1 side because this engine has not been running for a long time. It rotates freely, no internal bearing noise.
I did start the engine few weeks ago after a carb rebuilt (clogged) and it ran fine, at least stationary cause the clutch cable was broken.
I inspected the pad under the crankshaft and it is ok, no scoring. I guess I'm lucky, the crankshaft did not wobble too much due to the dead flywheel side bearing.
Could all the shavings come from this bearing ?
