1968 Sprint 150
1968 Sprint 150
behind my sprint headlamp there is a metal retaining clip. Can't find it on SIP or scooterwest. It holds the headlamp in place and mine is maybe a little bent as it's able to wiggle.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
1968 Sprint 150
1968 Sprint 150
no its a thin metal wire clip, kinda the diameter of a throttle, clutch brake cable etc... and it goes behind the headlamp I'll get a photo tonight
1968 Sprint 150
1968 Sprint 150
That clip.
@moto64 avatar
@moto64 avatar
Bend it back ? I doubt you are going to find that sold separately. Maybe someone's got an old unit they'd take it off of.
1968 Sprint 150
1968 Sprint 150
Yeah I'll try some online parts groups.
Even if you did find new repros of it, they'll be garbage compared to the og. I had to get new clips for my VNA headlight and the clips are MUCH thinner and weaker. I despise them. They barely work. I've lost half already.
1968 Sprint 150
1968 Sprint 150
Yeah that's when we need custom fabbed parts
@chandlerman avatar
Innovator
9 Days Since Last Explosion
Innovator
@chandlerman avatar
get some thin steel rod and bend your own. It's the only way to be sure.
It is made of pretty durable spring steel, so could be a chore to make one. These guys have it, but their shipping is ruthlessly expensive. I included one of these in a parts order from them, and it was good quality and actually fit.
https://www.mauropascoli.it/scheda.php?id=2975
@moto64 avatar
@moto64 avatar
Just bend the one you have back into shape.
An unfortunate result is that it will most likely break hence me having to order one. It is brittle spring steel. Anyway, give it go, mate, as there isn't much to lose if it does break.
@moto64 avatar
@moto64 avatar
Exactly. Just go easy. I'm guessing it shouldn't be straight but have a slight bow in it to "spring" the ends into place.
@xperimental21 avatar
Super
Super
I think you can make your own from a steel wire
1968 Sprint 150
1968 Sprint 150
I'll try it
splash_wave wrote:
I'll try it
I just got home from a quick ride around the neighborhood and lost ANOTHER one of the thinner newly made one. At this rate I'll have the 3 originals holding the light in and that's it by the end of the month
1968 Sprint 150
1968 Sprint 150
So you made some with success?
1968 Sprint 150
1968 Sprint 150
hth do you buy anything from this site as there is no buttons
splash_wave wrote:
I'll try it
Just don't use plain mild steel baling wire, use this instead.
Piano wire - Wikipedia
Piano wire, or "music wire", is a specialized type of wire made for use in piano strings but also in other applications as springs. It is made from tempered high-carbon steel, also known as spring steel. There are 23 different gauges of music wire, ranging from number 13 (0.775 mm) to number 26 (1.6 mm) in half-point increments.
@moto64 avatar
@moto64 avatar
tel 0544/502078 - fax 0544/502079
info@mauropascoli.it
I don't understand what that means. Regardless, the company has the part. If one looks for it in their list of parts for Sprint, SS180, it is there. The piano wire sounds like a good idea.
[ Time: 0.0147s ][ Queries: 4 (0.0079s) ][ live ][ 331 ][ ThingOne ]
