@oldfatguy avatar
Hurricane 200X, 2020 TW 200 (sold), 2022 Liberty 150
@oldfatguy avatar
Lots of center stand info in search function but have not found the answer. Want to know how far the
Liberty center stand lifts the back wheel. Recent hernia repair has me limited to picking up 15 pounds so putting bike on center stand is challenging.
OFG
@lottolearn avatar
2019 Liberty 150
@lottolearn avatar
2019 Liberty 150
About an inch, you can get a side stand fitted which would make your life much easier. The kit is about 50 bucks plus install.
Vespa GTS 300
Vespa GTS 300
You don't lift a Vespa onto the main stand, you kick the stand down, (almost) without any force from your hands.
It depends on the right technique, then it goes almost without force.
@oldfatguy avatar
@oldfatguy avatar
Side stand kit ordered. Will rewatch video on center stand technique. Thanks for the replies.
OFG
Vespa GTS 300
Vespa GTS 300
Stand to the left of the Vespa/Piaggio with your left hand on the left handle (secure with brake if necessary), right hand on the passenger handle. Step down on the stand without force (with the ball of your foot, with your right or left foot, depending on your preference) and swing the Vespa to the left/right until both feet of the stand touch the ground. Only when the Vespa/Piaggio is "balanced", give force to the stand and pull up / lift the pillion handle with the right hand (the left hand does NOT pull on the handlebar, but only guides, pulled brake must be released!).
@clampett avatar
2023 Primavera 150 2025 BV 400
@clampett avatar
From my point of view, it takes more energy to get on/off the Liberty than to put it up on center stand. That's unscientific and could be totally wrong. If a rider has issues with their left foot/balance, then I could see it being a bit more difficult. Otherwise, as stated by the 2 above, you just step on the stand and hold the scooter steady by holding the grab rail and it's up.
@jimjar avatar
2012 LX150ie
@jimjar avatar
2012 LX150ie
I agree that it is easy and doesn't need strength or lifting to get a scooter up onto the center stand…but it does take a little practice until you get the technique timing/balance set correctly into your muscle memory.
@oldschooot avatar
@oldschooot avatar
OFG
Pay the dealer to put on that side stand...Not fun for a healthy person 🙂
@crackedegg avatar
2018 Vespa GTS300
@crackedegg avatar
2018 Vespa GTS300
Robot shows how to install a side stand here. He also puts the Liberty on the center stand one handed.
@oldfatguy avatar
@oldfatguy avatar
A few tools to buy and ready to install side stand when it arrives. Will watch video a few more times.
OFG
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
Be caredul with the side stand since it doesn't have a kill switch it has a spring that will cause it to retract anytime the weight on it changes. A gust of wind or vibration from heavy equipment has caused folks to find their scoot laying on its side. Hopefully you can figure out the knack of putting it on the center stand as it takes no upper body strength. The procedure with emphasis on both legs of the center stand being evenly weighted is the key. Tilted either way makes it much harder.
@oldfatguy avatar
@oldfatguy avatar
The kit I have incoming is the same one Robot used in his side stand video. It does have a kill switch so the engine won't run with it down.
OFG
@lottolearn avatar
2019 Liberty 150
@lottolearn avatar
2019 Liberty 150
OFG
The stand won't retract on its own you have to kick it back. It stays in position unless you move it.
Yes, it will not start and it will shut down if the stand is deployed.
Very convenient when just moving the scooter, running in a store, moving out of the garage, etc.
Not so convenient if you then forget to turn off the ignition and remove the key when you're going into the store, or leaving it in your own garage...
But very handy for opening farm gates etc.
@lottolearn avatar
2019 Liberty 150
@lottolearn avatar
2019 Liberty 150
True.
I never use the side stand to shut off the engine, same with kill switch. To me the stand switch is there to prevent me from riding away with the side stand down, that can be fatal.
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
OFG
Then it is like the one that comes standard with the 2018+ GTS which is rock solid or at least as solid as any other kickstand.
@oldfatguy avatar
@oldfatguy avatar
And so it begins….. thanks to ROBOTs video got the panel (step one) removed in about 15 minutes. Helped to buy the exxxxxtra long #2 Phillips and low clearance screwdrivers.
OFG
@lottolearn avatar
2019 Liberty 150
@lottolearn avatar
2019 Liberty 150
If you have the tool for installing springs on brake shoes it works great for installing the side stand spring.
I also put the removed jumper for the side stand switch in the tool kit, just in case the side stand switch fails on the road. You can unplug the switch and plug the original jumper back in, just don't forget the stand position. Try and place the connector in a location you can reach without too much effort, another just in case moment.
@oldschooot avatar
@oldschooot avatar
OFG
For fun, take look at how Af1 Racing dealt with this Liberty side stand kit.
Guaranteed to put you right off purchasing one🙂
They followed Piaggio instructions.
@oldfatguy avatar
@oldfatguy avatar
Makes me even more thankful for ROBOTs videos.
OFG
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
You are correct about the non-kill switch side stand, a spring loaded tip over waiting to happen
[ Time: 0.0126s ][ Queries: 4 (0.0052s) ][ live ][ 339 ][ ThingOne ]
