CaliforniaCruising wrote:
What if it is still the ECU, your 8 GTS still also have the same problem? Maybe the ECU shop scabbed off the new GTS was also bad?
Or the ole dreaded too much gas in the emissions canister?
Yes, for me it could be too much gas because I often get close to the top of the chamber, even using the Gas Funnel that Scooterwest sells.
Here's my fix, which seems to work all the time. I believe this issue is related to the fuel pump/pressure at early morning start. It's been warm here lately and I think the pressure of fuel into the system drops a bit hours later. What I do is turn the ignition 3 times, such that you hear the fuel pump pressurize three times. Then I start it and it starts every time, without the engine cutting out at all. If I do it twice, sometimes it will die. If I turn the ignition to pressurize the system just once (as we should be able to), the engine may or may not stay alive -- but three times, it works every time!
All 8 of my GTS's do this. Sometimes they don't and sometimes they do. Totally random and not unique to any one Vespa. They seem to run fine all day and not require more than one "Pressurization" by turning the ignition more than once as the day goes on. I think the fuel pump doesn't run long enough to pressurize the system and that's where the real issue is, because it can be overcome by doing the above!
I never noticed this in the cooler months but it may not matter. All of my GTS models have the updated Fuel Pump, not the faulty one that my 22's had.
